[Jolla Phone (2026)] Poor quality of the USB board PCB
REPRODUCIBILITY: ?
OS VERSION: N/A
HARDWARE: Jolla Phone 2026
UI LANGUAGE: N/A
REGRESSION:N/A
This is actually a hardware “bug”, not a software one. The USB board of the Jolla Phone 2026 is manufactured with a process that is not suitable for its intended use. My phone, after just some months’ usage, started to experience random charger disconnections while connected to the car charger. These worsened to the point that it only charged pushing up the USB-C external connector. Opening the device, I found that the tracks connecting to the USB connector on the board had broken and the connector pads had detached from the FR4 substrate. Since designing boards is my job, I can tell for sure that this is due to cheap material/processes and thin tracks.
  1. I just used the phone as I do with my other phones.
The connector keeps working.
The connector does not work reliably any more.
None.
I suggest that the process/manufacturer be changed in order to withstand normal mechanical stress on the connector pins (ie tracks stick better to the FR4 substrate), and possibly thicker copper on the top layer to withstand micro-bending.
No surprise here and amazing that after so many years this still is a very common issue in phone design.
I refer also to the USB-C → 3,5mm jack threads that seem full of “solutions that work” until they reproduce the above problem due to excess lateral / axial mechanical stress on the port’s socket.
So while you were in there, did you see a possible fix?
Pictures that illustrate the damage welcome.
I like 1 oz. That will withstand more than just micro-bending :slight_smile: Kidding, of course, but it’s what I use on the PCBs I make and is sufficient for sturdy eurorack front-plates that get a ton of connector activity. But, that’s also top AND bottom :slight_smile: I like copper.
My personal workaround is to use those little magnetic plugs.
Random example on Amazon
I rarely need USB for anything but charging, and they also convert any charging plug (lightning, USB micro, mini, C,…) on any device into one universal “Socket”, so I only carry one type of charging cable.
Works For Me ™.
Of course they have other problems: the cables break frequently, if you drop the device so it hits the floor facing the plug, your socket is almost guaranteed to be damaged, you lose USB-C features. Cases/sleeves often need modification.
Yes, I’ve been looking to these as well but they bring no 3,5mm headphone jack.
Used such thing on an iPhone SE 2020 with lightning port with great success but then decided I needed to listen to music with an adapter and in no time the port was worn out internally, even not ripped from the PCB but simply mechanically worn out after too many connects / disconnects. Even with regular “greasing” of the sliding contacts.
I’m looking for a solution like a low profile L shaped USB-C plug with ribbon cable that leads to the back of the cover where it offers a glued on combo USB-C and 3,5mm stereo connector.
Edit: something in the style of this but better.
I had a colleague scratch the solder resist and re-solder at least the power pins. It charges now but data won’t work.
I believe the surface copper on this board was 0,5 oz. Not a wise choice, I guess, also considering the current that should flow in those tiny tracks.
I used to use those on tablets that I keep at home, but for phones that I carry and charge in many different places it’s a bit harder.
Can you show some pictures maybe for educational purposes?
And a question that might or might not be related. Do you have a phone with the i2c or the revised i3c board?
I’m not saying that there should be any difference on that part of the board, but it might help exclude or verify a certain issue for Jolla team.
Not quite, since my phone was turned off when it was opened and my backup phone is an Xperia 10 V… well, you know.
Mine is maybe one of the first 10 phones or so sold, so it still has the old board.
By the way, since it’s the same board, I guess I will at least fix the I3C issue as soon as I can grab one.
I’ve given up on 3,5 mm headphone jacks as soon as I found out that there are some DACs out there that crush any internal phone hardware in terms of sound quality, from the cheap but crisp Apple dongle to something more refined such as the Moondrop Dawn 2 Pro. I now use external DACs even on devices with a 3,5 mm jack. You can get a splitter on Aliexpress to connect the DAC and keep a charging port at the same time.
Only the XperiaX 3,5mm is good enough (podcasts, voice, hardly any music listening).
That aliexpress dongle brings the same potential issue (?): leverage on the USB-C port of the phone. For that reason I rather listen to inferior sound through 3,5mm.
Yeah, copper at a half is almost paper. That will be nigh impossible to repair. Man.
I’ve also gone this way. And I don’t even have an expensive dongle (I have the apple, too, but prefer a higher gain one).
It’s a good question. Not all usb surface mount connections are equal, but the same can be said of 3.5 mm mounts. My gut feeling is that a 3.5mm plug will last longer simply because it is just a ‘hole’. The surface mount types I use have large pads and require a lot of force to break off a board (with large pads).
Jolla should offer the USB-C board at a fair price, preferably with a redesign, to strengthen the USB-C port. After all, that board should be rrasonably easy to replace by users, inclined to do it themseleves.
Agree. And do so regardless of the of the USB-C mount quality.
It is still a single USB-C port to last for the next 13 or so years.
In following official topic about spare parts I already made the suggestion “Looking foward to see a USB-C replacement kit.”
Maybe you all can do the same?
https://forum.sailfishos.org/t/jolla-phone-spare-parts-and-accessories/
The board is indeed fairly easy to replace, I already took it out a couple times. In this respect the phone is extremely well built.
I remember I expressly asked for replacement charger boards and for a dual USB port in the specification collection phase.
We have already been promised a replacement board to fix I3C connectivity.
I think we just have to wait a bit longer. Jolla is, in lack of better words, appearing to try really hard. With the employee number they just struggle with speed and with customer service.
I think if they don’t come up with something until when they will surely have more air to breathe, once the pre-orders have caught up, we should certainly remind them of replacement USB-C boards and a solution for battery shipping.
I tried one of those a few years back, but i must have had a poor quality one as the touching parts would get very hot to touch when charging.
Is that something you’ve encountered?
I have seen contact problems sometimes (resulting in wonky charge current) but I haven’t noticed heat issues.
That being said, there’s many different types out there, presumably all from China, and quality may vary among the products.
