Device: Jolla Phone 2026 (MediaTek) ā OS: Sailfish OS 5.2.0.22 Finlayson
Summary: When Wi-Fi is associated (even fully idle, screen off, overnight), the device draws ~16 mA average instead of ~6.6 mA in airplane mode. iw dev wlan0 get power_save reports on, but the radio clearly never enters its low-power state. Additionally, after ~12 days of uptime the WLAN firmware can wedge (repeated HAL errors), blocking system suspend until a reboot.
Battery measurements (full charge-cycle comparisons, same usage pattern)
| Configuration | Overnight drain | Average current (3760 mAh battery) |
| Airplane mode, Wi-Fi off, all night | 2 % / 11h25 | 6.6 mA (~0.18 %/h) |
| Wi-Fi associated, idle, screen off, all night | 5 % / 11h40 | 16.1 mA (~0.43 %/h) |
Delta attributable to Wi-Fi: ~9.5 mA continuously while associated (~+6 %/day).
Battery itself is healthy:
CYCLE_COUNT=2,CHARGE_FULL == CHARGE_FULL_DESIGN(3760 mAh), HEALTH=Good. -
For reference, other Jolla Phone 2026 owners report ~2 %/9 h standby ā matching the airplane-mode figure, so this looks device/driver-specific rather than expected behaviour.
iw dev wlan0 get power_saveāPower save: on, yet the current stays high, so the driver/firmware appears not to actually apply power save (no FwOwn / PS transitions observed).
WLAN firmware wedge (intermittent, after ~12 days uptime)
Kernel log, repeating every ~10ā20 s:
kernel: [wlan][N]soc7_0ForceEnableHostCsrIrq:(HAL ERROR) Polling conn_infra ID failed. (0xdeadfeed)
connmand[3221]: handle_nl_command_error: error: -22
connmand[3221]: suspend_set_wmtwifi: TESTMODE command failed.Ignore if the kernel is using a gen3 wmtWifi driver.
kernel: [name:spm&] Pending Wakeup Sources: WLAN_TxEvent ...
During the wedged state, /sys/kernel/debug/wakeup_sources showed the WLAN sources blocking system suspend for hours (e.g. WLAN_Ioctl prevent_suspend_time ā 6.5 h, WLAN_FwOwn ā 2.8 h over ~12 days). A reboot cleared it completely (counters reset, no errors, suspend healthy again). The weather application looping was a symptom of the degraded network state, not the cause.
What was ruled out
Battery hardware (see fuel gauge data above).
msyncd / sync framework, closed applications, Bluetooth, and cellular radio: tested independently (airplane-mode nights, masked msyncd, closed apps + BT off) ā none of them changes the ~9.5 mA Wi-Fi delta.
The wakeup is not from network traffic: Wi-Fi was fully idle during the overnight measurements.
Request
Is a low-power (FwOwn / power-save) failure of the MediaTek WLAN firmware known on this device?
Any known workaround (driver parameter, firmware update) to keep the radio from drawing ~9.5 mA while associated?
Happy to provide additional wakeup_sources dumps or kernel logs if useful.
