REPRODUCIBILITY: Persistent
OS VERSION: 5.2
HARDWARE: Jolla Phone 2026
UI LANGUAGE: English (UK)
REGRESSION: No navigation possible
Location services not working, navigation not possible. Neither in Sailfish native apps, nor in Android (microG) apps. GPSInfo Sailfish app can't find any satellites.
Location is on, High-accuracy positioning is on, and I have tried custom settings. I have taken the phone outside for more than 20mins with WiFi and Location services on trying to get a fix. Didn’t help
I would like to use navigation
Turn on the phone and location services
Usable navigation apps
GPS not working
haven't done anything, just stock Sailfish OS. This is my first Linux phone ever, I'm not smart enough to tinker with it
First toggle gps on/ off with gps info active.
If no help reboot the phone make sure gps is on and start gps info.
Outside you should start seeing sats.
Takes maybe 10 minutes for first fix ( loads a lot of calendar etc. Data at first time) . When first fix made should be very fast to fix
Similar bug reports already made and all started to work.
This has indeed helped. Thank you.
I did try this approach the first time, but only with WiFi, without a mobile internet. Now I’ve found a SIM card to pop in.
And I do apologies for not finding this solution myself (I did try, both Google and the search here on the forum).
I guessed “gps info” meant “GPSInfo” in the Jolla Store (by balta). In that app’s ribbon menu there is an activate/deactivate GPS which is probably how do you toggled the GPS on/off. I have tried that before and after a reboot (outside with good sky visibility). It says GPS active but zero satellites
Does this mean I may not be able to test the GPS until after setting up my SIM card?
I don’t remember that working. You should turn location on in the top drag down menu.
Location services are on. GPSInfo reports the GPS is “active” yet sees zero satellites. The compass direction is working.
It is possible I have a broken unit, but I rather suspect a bug. I may have to try the SIM card sooner rather than later…
Anecdotally, getting a GPS fix on a Jolla Phone (2026) without a SIM card was close to impossible. When on WiFi, the phone would get approximately the right time but the wrong time zone - and I think correct time is essential for GPS to work.
What does CSD says? Five taps on version number in Settings.
I have swapped over my SIM, and now GPS works - got a fix quickly indoors. Annoyingly GPSInfo doesn’t seem to give any feedback when Location services are off. I also briefly tested with OSM Scout and Pure Maps.
This is with Sailfish version 5.2.0.22.
I use both OSM Scout and Pure Maps with offline maps.
OSM Scout lets you track your movements, which Pure Maps doesn’t, and it has maps better suitable for outdoor activities while being offline.
OSM Scout and Pure Maps handle differently, but both are good apps. See which one you prefer - or keep both, as I have
(Edit: restructure to remove ambiguity.)
Sadly I’d already put in the SIM card before seeing your post. Test tool CSD | Sailfish OS Documentation explains how to get the CSD tool. It naturally reports GPS is working now, using 25 of 48 satellites in view.
Pure maps with OSM Scout Server does that nicely.
Not sure which of the various statements “that” refers to, but I agree, Pure Maps is good
, really good.
If you setup Pure Maps with OSM Scout Server you can have offline navigation.
Ok, I see there was ambiguity in my post. (Although I did start by saying I use both offline.) I have now restructured it to make it clearer.
Hi all. I managed to get gps working on jolla 2026 with pure maps but google maps is not getting a location. Is there a specific setting for the android side?
Just a question… For what would you need to use GoogleMaps on a Jolla Phone? If you really need an Android maps application then perhaps OsmAnd~ from F-Droid has all one could possibly dream of incl. public transport.
I haven’t really used osmand much. Is it as good as google maps? At times i need it for work.
