I’m not sure if this is related, but I noticed a similar problem when trying to answer an SMS on the lock screen – can’t enter the PIN code afterwards (can’t send the SMS either) unless I first open the camera (by sliding up from the bottom edge), then PIN touch starts working (the SMS is lost though).
Just to update. I have disable the pin code and same behavior the digitalizer don’t work. But all the buttons are working and I have feedback from the OS.
Hi guys, Any one have a idea to help diagnostic this? is a way to have the digitizer test always running. Or to connect a Bluetooth mouse that replace the digitizer? So i can’t maybe narrow down if is really a hardware issue or from something in the OS is stopping working.
I have connect a Bluetooth mouse and works even if the digitizer stops working. Using the mouse I was able to unlock and using the utilities I have tried the Home screen restart. The digitizer start to respond again.
