Jolla Phone 2 Company conditional access / MS Intune
Anybody figured out a way on how to possibly enroll the J2 in MS Intune and access corporate resources/apps ? This is a MAJOR SHOWSTOPPER for me to use Jolla as a daily driver since the adoption of conditional access policy which is nowadays very common in business.
Hi,
Did you try the apk from MS website ?
You can install it but it won’t work
Can you share more info ? Any error code ?
Nothing happens: it will go in a kind of loop trying to enroll the device. No errors. Work profile is enabled in Micro-g
If your company force Google Play integrity, it will probably never work.
Some Play integrity bypass exists, but it’s heavy hacking.
Did you find any solution? i am running into the same problem.
Nope. As far as I can understand there is no solution. :worried: Actually that is the main reason which lead me to (reluctantly) sell my J2 …
