OSVERSION: 4.5.0.21
HARDWARE: Sony Xperia XA2 - h3113 - h3113 - 1.0.0.13 - armv7hl
UI LANGUAGE: Italiano (user: it_IT, os: it_IT.utf8)
REGRESSION: not specified
Sometime it happens that despite the cover is set right, same cover is shown for multple albums, and that is very tedious
Some records are needed
Put some songs into the phone
Open the default media player
See different albums having the same cover
EXPECTED RESULTS:
Having the right cover for the right album
ACTUAL RESULTS:
Cover is the same for different records
Patchmanager: no
OpenRepos: yes
Chum: yes
Other: none specified
All files are my own, legally bought on bandcamp so tags are correctly set and this is the only player where it happens as on unplayer and on pc everything is set right
Home Encryption: enabled
the initial version of this bug report was created using Bugger 0.9.10+git1
You shall provide more detailed info to let other people help you. Fe. what is lacking is the naming scheme or tree pattern you use to organize your files and naming convention of your album covers.
I also heavily use the default media player, and I observe no such problem. Here is my tree pattern:
Author
** Album name
*** music files.(mp3 | ogg …)
*** ${album name}.(png | jpg …)
One record is called “just drive (part 1)” and another record is called “just drive (part 2)”
They are in separate folders and of course part one and two are part of the title so it’s correctly set on the album tag
The cover is actually embedded into the files so no cover/art/coverart dot jpg/png or so, and of course is the right one for each album
Still they have the same cover, in this case the one from part 1
I bought those files from bandcamp, so didn’t tag anything, they were already tagged by the label/artist
Now, i had a similar problem with similar files (same bandcamp with same label, different artist) where i was having double entries for the same record
Couldn’t find the culprit, then discovered 3 files on the record had a comment, the others a description, so the default jolla media player was treating them as a separate records
It’s quite absurd if you consider no other player is doing this but ok, it may be since there was a different tag (althought album and artist were exactly the same)
But now the cover is embedded, and it’s a different cover so i don’t think it has something to do with my tags?
Maybe tracker (or some higher layer) discards what’s in parenthesis and causes a collision.
None of my media have important stuff in parenthesis.
Try tracker3 info on files in both albums and see what it thinks about them.
(Though i can’t get that to display anything for files on the SD card, even though they are indexed just fine).
So, i have modified the tag for a single file, removing the (), and the default media player created another entry with the correct album cover
This may prove tracker does not like () but unfortunately it does happen on other files too, with completely different album names, and no special characters at all so i’m not really sure this is the culprit (not entirely anyway)
Just drive has the same exact problem, so now we know is an ellipsis thing (althought i don’t know why create another entry, release date maybe?)
But i do not have problems with the other record (the one in the first screenshot) so it must be something jolla’s side, i guess…
Althought i need to say that i have tons of other problems with gnome-music all due to tracker probably…
Digging this a bit. It’s not tracker which cares about parenthesis but libmediaart and the gnome media art storage spec it’s using. DraftSpecs/MediaArtStorageSpec - GNOME Wiki!
Basically it strips content between (), among other mutilation to the titles.
Probably best if some day the whole libmediaart is replaced by a custom solution. It’s not really even doing much more than making some heuristics on what could be a cover file and providing saving mechanism for externally fetched (=embedded) cover art.
