Jolla-Camera shows coloured bars and gray grains. (Seems to be some Gstreamer default)
[nemo@Sailfish ~]$ jolla-camera
gst-plugin-scanner: /usr/share/droidmedia/hybris.c:53: __resolve_sym: Assertion `ptr != NULL' failed.
ALSA lib conf.c:3817:(config_file_open) cannot access file /etc/alsa/conf.d/50-arcam-av-ctl.conf
ALSA lib conf.c:3737:(snd_config_hooks_call) function snd_config_hook_load returned error: No such file or directory
ALSA lib conf.c:4201:(snd_config_update_r) hooks failed, removing configuration
[W] unknown:0 - no alsa devices available
[W] unknown:20 - file:///usr/lib/qt5/qml/com/jolla/camera/settings/CameraDeviceToggle.qml:20: TypeError: Cannot read property 'length' of undefined
[D] onCompleted:105 - ViewPlaceholder requires a SilicaFlickable parent
[nemo@Sailfish ~]$
How do I fix this?
(It’s not hardware failure because the camera is usable with an Android app.)
Background: After upgrading to 4.3.0.12 the camera app wasn’t starting up/crashing.
Read in a forum post that deleting the contents of /home/nemo/.cache/gstreamer-1.0/ would fix the issue.
Deleting the cache did get the app to start up but it can’t seem to access the camera anymore and instead shows the GStreamer test bars and gray grains.
Also read elsewhere that “/usr/bin/killall minimediaservice” would fix the camera but that doesn’t help either.
I’m unable to uninstall/re-install the camera app
[root@Sailfish nemo]# pkcon remove jolla-camera
Resolving
Querying
Testing changes
Finished
Fatal error: This request will break your system!
