I am still new to this community trying to find my way through
After having received my Jolla Phone yesterday (YEY!!) , I am in the process of setting it up. One of the first things was contacts and calendar. So I tried to add a caldav account with both contacts and calendars pointing to my NAS.
Turns out, that contacts works nicely, while calendar doesn’t. I tried all kinds of URLs and extra paths, which I could find in this forum or via normal search on the internet, but without any success.
So I installed CALDAV from F-Droid, configured it and it immediately found all my calendars. However, the Jolla Calendar App just wouldn’t pick them up. In the end I gave up with Jolla calendar and install Fossify Calendar from F-Droid, which just worked like a charme without any issues now being able to see all my appointments in both my calendars.
Anyone any idea, why neither the Jolla app nor the account set up would allow me to add a Synology NAS calendar?
It states, that account is created and then gets stuck at the end when trying to receive the llist of calendars
But no account gets created …
I also verified the calendar is all good on the NAS side as well as the login info, which is also proven by the fact, that it does work with the other calendar app
Just can’t think of anything else I potentially could have tested …
Can you try to see what’s wrong using the command-line DAV client:
If you figure out how to get the calendar-list using the CLI client, the same code is responsible behind the scene for account creation and later synchronisation. So it may help you to find what to put in the setting when creating the account.
I would also be interested in a solution, since I have exactly the same problem.
I had set up a working caldav connection a couple of months ago between a Synology NAS calendar and the Jolla C2 and also Xperia 10 II (with SailfishOS). For the C2 it looks like it broke a couple of weeks ago, the Xperia 10 II still seems to be able to synch. Settings in UI between C2 and JollaPhone seem to match; for Xperia 10 II, user is different, but paths still match. At the moment my guess is some authentification issue (perhaps similar to the e-mail issue described here: [Release notes] Pispala 5.1.0.11 - #694 by dcaliste ). I did not yet check out the logs of above comand line, but could provide this information, if required.
For the time being I use the caldav and Fossy calendar from FDroid, which works so far. But I want to understand, what is going on, so will keep digging
I am using just a local IP address and no https. At the moment my NAS is only available in my local network, so I did not set up https or DNS (- the address that the webinterface provides for caldav only shows http:// with IP address).
resulted in a list of calendars I have access to. Selecting the ones I needed resulted all their entries to be added to the Jolla calenfar app lile a charme
Haven’t tried https, but the only diff should be the port
@fingus- your format was just missing the /home at the end. Without it wouldn’t have worked for me. Maybe different NAS version or DSM calendar version?
