Hello - ive searched but cannot find an answer so I will ask my silly question
Ive managed to damage my C2 the sim slot got stuck and then ….well I had to force it out
My local cellphone repair shop have never seen a Jolla before
Which is the nearest common model in general circulation that is similar enough to the C2 for a sim slot repair?? It looks like a Samsung to me but im not a tech guy
New to all of this forum thingy so please Jolla Community, don’t lynch me if i am posting the wrong way
I too got a repair issue. I dropped my phone (which happened with various phones a lot in the past and usually only the protective glass or worst case the display breaks and needs replacement) but this time the protective glass broke, the display is not broken but it stopped working correctly (all black, some light around the edges, when i press on it it faintly works but i cannot press it and use teh touch function at the same time). Only one impact was enough apparently to displace some contacts inside. I am not tech savvy and don’t trust my skills in trying to fix it myself, hence i want to send it in for repair. I have all my data locally on it, no cloud service, no backup, so i really need the fastest possible repair of the display just to save and transfer some data. @Jolla is there ANY express way to get the display repaired and sent back to have a functioning primary phone asap? To transfer some apps i need to authenticate on this very device so a new replacement will not do the trick i am afraid
Posting here additionally to the e-mail because of urgency and please don’t lecture me on backing up my data, believe me, i regret it enough as it is :') thanks for anyone’s help either with current email processing times at Jolla, Infos about repairs (and costs), a replacement screen being sent so i can give it to a technician, ANYTHING
Oh, I’m sorry for your issue.
I doubt that Jolla has a capacity for such a fix. I guess your best bet is to find a phone service workshop which has a capacity and/or experience with Reeder brand phone (which C2 is) repairs. You can ask them to not erase/flash your phone so the chances for data retrieval are higher. An option for cheap spare parts is to search for a SFOS users from Turkey. They can send them to you or workshop I guess.
Good luck.
PS: there was a bumper case for C2. At least I bought it.
oh man that is such a bummer i mean what does a user do if the display is broken, it happens… instead of discarding the phone it’s way more sustainable to get a repair or a spare part. the reeder it is based on has different (round) edges so it is not compatible i would need an actual jolla display instead. i really wanted this phone to work as my primary. thanks for your reply nonetheless i will get a different phone in the meantime and hope jolla will repair it.
I bought the “bumper” too, and had it on, but it is more like a thin protector, not really shock absorbant.
on a different note, i couldn’t find anything in the forum about a strange clicking sound that i experienced during phone calls as if there was an issue in the hardware of the speaker? but i hadnt noticed it when listening to videos on speaker, only during phone calls so the issue lies with the phone speaker next to the ear only.
Sorry to hear that you dropped your C2. Based on what you wrote, it seems to me that the glass is not broken, you had the Jolla screen protector protecting it, but the screen itself is black, so I assume a connector inside the phone became loose. My advice is, first try to make a backup of your data. Secondly, open the phone and fix the screen issue by re-connecting the screen connector ribbon cable. Even if you say that you are ‘technically inept’, it’s never to late to learn a few basic phone fixing skills. We can motivate and assist you as best as possible. Let’s start with issue 1. - backing up your data. A few questions first. Have you enabled the Developer Mode (dev-mode) and SSH connection? If yes, then it’s easy to remotely via pc/laptop in your home WiFi backup all your data without the need to touch your screen. In case you have not enabled dev-mode & SSH, then the other option to try a backup is the “Recovery Mode” via USB cable, connecting your broken C2 to pc/laptop and Telnet while you turn first off and then on your phone, subsequently press-and-hold down the ‘Volume-down’ button. At the same time open a terminal in Linux / Windows and type, best follow this guide from Jolla: https://jolla.zendesk.com/hc/en-us/articles/204709607-Jolla-Phone-How-to-use-Recovery-Mode
Perhaps you did not check for the correct hardware. Please search for ‘Reeder s19 max pro S screen repair’ e.g. from YouTube and you see that’s actually the same hardware, same screen as the C2 variant. I would suggest to watch some related videos. It’s not very trivial to fix or replace a broken screen if you haven’t done it before but it’s possible with good phone fixing tools and a hairdryer. The hairdryer is the first item you need, and plastic scalpel as you need to open the backside of the C2 first. Some patience is needed with the hairdryer and please do heat up just the outer sides of the phone backplate im order to get the default glue soft enough, then asap take the plastic scalpel…basically just follow the YouTube videos where they show how to open the Reeder s19 max pro S. The rest is just following the steps shown in the videos until you get to the screen.
Here is one option for a replacement screen. It seems to be a Chinese seller, so I don’t know about additional taxes. Usually, I have good experiences when ordering spare phone parts from China. The new EU taxation is, of course, another topic.
