[Jolla C2] MMS fails with operators using a separate MMS APN – no route installed for MMS context (gateway 0.0.0.0)
REPRODUCIBILITY: 100 %
OS VERSION: 5.1.0.11 (Pispala); hw release 1.1.0.12; ofono 1.29+git12-1.16.4.jolla, ofono-binder-plugin 1.1.25-1.12.2.jolla, libgbinder 1.1.45-1.15.1.jolla, libgbinder-radio 1.6.1-1.9.2.jolla, mms-engine 1.0.83
HARDWARE: Jolla C2 (Reeder s19mps)
UI LANGUAGE: Norwegian (bokmål)
REGRESSION: Unknown — issue present since first setup of this device; no earlier release tested on it
MMS sending and receiving fail with a deterministic 60-second timeout when the operator uses a separate MMS APN (tested with Happybytes, an MVNO on Telenor Norway: MMS APN mms, MMSC http://mms.media, no proxy — the exact settings published by the operator). Ordinary internet over the internet APN works fine throughout.
Root cause, verified live on the device: when mms-engine activates the MMS context, oFono’s binder plugin reports the data call settings (address, DNS) but no kernel route is ever installed via the MMS interface (seth_lte1). The data call reports gateways=0.0.0.0, and because the MMS context is not managed by connman (it is activated standalone by mms-engine via oFono D-Bus), it — unlike the internet context — receives neither a prefix route nor an on-link default route.
mms-engine binds its HTTP session to the MMS interface address (SOUP_SESSION_LOCAL_ADDRESS in mms_task_http.c), but routing is destination-based: the TCP packets leave via the internet APN’s default route (default dev seth_lte0 scope link) with a source address from the MMS pool, and the operator’s ingress filtering drops them. libsoup’s default 60 s session timeout then surfaces as HTTP status 7 (Connection terminated unexpectedly).
Proof: with a host route via seth_lte1 forced in as root, the MMSC answers immediately — curl from the MMS source IP gets HTTP/1.1 405 Method Not Allowed, Allow: POST,OPTIONS (the expected MMSC reply to a GET) — and a real MMS sent from the Messages app succeeds, including reception of the MMS notification. Network, provisioning, APN settings, MMSC and mms-engine are all fine; the only missing piece is a route via the MMS interface.
  • A SIM from an operator that uses a separate MMS APN (Telenor Norway and its MVNOs qualify: APN mms, MMSC http://mms.media, no proxy).
  • MMS access point configured per the operator’s instructions (Settings → System → Mobile network → MMS access point).
  • Mobile data working normally on the internet APN; WiFi switched off (not required for the bug, but keeps the analysis clean).
  • For observing the internals: developer mode enabled, SSH over USB.
  1. Insert the SIM, configure the MMS access point as above (APN mms, MMSC http://mms.media, MMS proxy empty).
  2. SSH in over USB and watch interfaces and the routing table:
    while true; do ip -4 addr show seth_lte1 2>/dev/null; ip -4 route show; sleep 1; done
  3. From the Messages app, share a small picture to your own number.
  4. Observe that seth_lte1 comes up with a 10.120.x.x address — and that the routing table never gains any route via seth_lte1.
  5. Wait ~60 s and watch the message fail. mms-engine retries roughly every 76 s, ~11 attempts total, then the message is permanently failed.
  6. Optional counter-proof, as root:
    dbus-send --system --print-reply --dest=org.ofono /ril_0/context2 \
        org.ofono.ConnectionContext.SetProperty string:Active variant:boolean:true
    ip route replace 148.122.173.15/32 dev seth_lte1
    ip route replace 148.122.173.79/32 dev seth_lte1
    curl -4 -v --interface 10.120.95.111 http://mms.media/   # → 405, Allow: POST,OPTIONS
    Resend the MMS from the app while those routes exist → it succeeds and the MMS notification arrives.
When the MMS context is activated, a usable route via the MMS interface (seth_lte1) is installed (on-link default route or equivalent source-based routing), so that the MMS POST bound to the MMS source address reaches the MMSC. The MMS is delivered and the incoming MMS notification/content is retrieved — as it does on Android handsets with the same SIM and the same operator settings.
seth_lte1 comes up (e.g. inet 10.120.95.111/32) but no route referencing seth_lte1 is ever created. Routing table captured live while the MMS context was UP:
$ ip -4 route show
0.0.0.0 dev seth_lte0 scope link
10.0.0.0/8 dev seth_lte0 proto kernel scope link src 10.8.167.111
10.8.167.0/24 dev seth_lte0 proto kernel scope link src 10.8.167.111
192.168.2.0/24 dev usb0 proto kernel scope link src 192.168.2.15
Consequently every MMS send fails after exactly 60 s. mms-engine log (identical for every attempt, 30+ attempts across all configuration variants):
[mms-task-http] MMS interface address 10.120.105.253
[mms-task-http] m-send.req (261475 bytes) -> http://mms.media -> m-send.conf
... exactly 60 s later ...
[mms-task-http] HTTP status 7 (Connection terminated unexpectedly)
m-send.conf is 0 bytes — the MMSC never answered, because the SYNs went out the internet APN with a foreign source address and were dropped by the operator. MMS reception (notification content retrieval) fails for the same reason.
  • OpenRepos packages installed for diagnostics: MMS Logger 1.0.20, oFono/sailfish-log-viewer.
  • Developer mode + SSH enabled.
  • After diagnosing, a workaround systemd service (mms-route-fix.service, runs a small script that adds host routes to the MMSC via seth_lte1 whenever that interface is up) was installed — with it, MMS works flawlessly. All attached logs were captured before the workaround was installed.
  • No other patches, no WayDroid, no alternative repositories.
oFono activates the MMS context without any error (ofono.log):
binder_data_call_new_aidl() [status=0,retry=-1,cid=2,active=2,type=0,
  ifname=seth_lte1,mtu=0,address=10.120.105.253,
  dns=148.122.173.7 148.122.173.77,gateways=0.0.0.0,pcscf=]
setting up data call
mtu_limit_apply() seth_lte1 mtu 1500 => 1280
pri_update_mms_context_settings() proxy mms.media port 80
Counter-proof with forced routes (context up, root):
# ping -c2 148.122.173.7                    # MMS-APN DNS via seth_lte1
64 bytes from 148.122.173.7: seq=0 ttl=60 time=88.668 ms
# curl -4 -v --interface 10.120.95.111 http://mms.media/
* Established connection to mms.media (148.122.173.15 port 80) from 10.120.95.111
> GET / HTTP/1.1
< HTTP/1.1 405 Method Not Allowed
< Server: nginx/1.29.3
< Allow: POST,OPTIONS                        ← MMSC alive and reachable
End-to-end success with routes held in place — journal:
Sep 30 00:38:04 JollaC2 ofonod[1479]: 2f 6d 6d 73 2e 6d 65 64 69 61 2f ...  /mms.media/3ePw3...
Sep 30 00:38:04 JollaC2 ofonod[1479]: plugins/sailfish_pushforwarder.c:
             pf_handle_datagram() content type application/vnd.wap.mms-message
Workaround in use (systemd watchdog; MMS then works fully automatically):
#!/bin/sh
IP=/usr/sbin/ip
IFACE=seth_lte1
MMSC_IPS="148.122.173.15 148.122.173.79"   # mms.media (Telenor NO)
while true; do
    if "$IP" -4 addr show "$IFACE" 2>/dev/null | grep -q "inet "; then
        for ip_ in $MMSC_IPS; do
            "$IP" route replace "${ip_}/32" dev "$IFACE" 2>/dev/null
        done
    fi
    sleep 1
done
Suggested proper fix (source level): install source-policy routing for MMS contexts — e.g. in oFono core (src/gprs.c) when a context of type MMS is activated with IPv4 gateway 0.0.0.0/unset, add (and remove on deactivation):
ip rule  add pref 100 from <mms_ipv4> lookup <table>
ip route add default dev <mms_ifname> table <table>      # on-link default
This mirrors Android’s per-network routing tables and cannot interfere with the default internet route. Alternatives: synthesize a usable gateway in binder_gprs_context_set_gateway() when the data call reports 0.0.0.0, or let mms-engine (mms-connman-nemo) manage the route for its own connection (grant CAP_NET_ADMIN). Regression criteria: MMS works with separate-MMS-APN operators and with proxy-based MMSCs; ordinary traffic still uses the internet APN during transfers; no routes/rules leak after context release.
rename “workaround.targz” to “workaround.tar.gz”, unzip and follow instructions in readme or setup manually.
workaround.targz (3.4 KB)
Files and instruction for the workaround added.
have you tried configuring mmsc ip as a proxy for itself?
Tried it now and it works. Two findings then:
It works only if the real MMSC hostname is kept. With MMSC = http://mms.media + MMS proxy = 148.122.173.15:80 (the MMSC’s own IP), a real send/receive completes fully — every MM1 transaction (send, notification, retrieve, acknowledge) HTTP 200 in ~2 s.
Watching the routing table while toggling the proxy (context cycled via D-Bus) shows that the system installs a host route for the MMS proxy via the MMS interface (oFono src/gprs.c: pri_update_mms_context_settings()), but never for the MMSC host itself. Empty proxy → no route at all → mms-engine’s SYNs, bound to the MMS source address, egress via the internet APN’s default route and are silently dropped → the exact-60-second timeouts. Your trick feeds the MMSC IP through the proxy field, making the system itself install the missing route.
On the gateway 0.0.0.0: that’s normal for LTE point-to-point bearers, reported by the modem — not an operator misconfiguration; the same SIM works on Android. The internet context gets an on-link default from connman, but the MMS context is activated standalone by mms-engine and gets nothing except the proxy special case — which is gateway-independent, hence the trick works despite 0.0.0.0. So, the defect is simply that the special case covers the proxy and not the MMSC.
Workaround caveat: with the proxy IP hardcoded, if the operator moves the MMSC, MMS breaks silently.
Possible fix: route the resolved MMSC host exactly like the proxy when no proxy is set —
via <gateway> if the data call provides a real gateway, on-link otherwise.
For reference only: link to providers’ setup instructions for internet and MMS on Android: Kundeservice - Trenger du hjelp | Happybytes
