Hi,
what is the maximum capacity micro sd card for Jolla C2?
Thanks
Search before posting. SD size limits are artificial (filesystem-related) anyway, not to mention a thing of the past.
Thank you for your answer. Unfortunately, I am a technical layman and find the insinuation that I did not research beforehand a bit inappropriate. I did it, but unfortunately I did not understand anything. If my research was not sufficient, then in future a friendly comment or no comment will suffice. Thank you and have a nice day
I have personally given versions of this answer in this very forum, in similarly simple terms, several times before; those should be findable. ![]()
Here are some answers to your question:
Thanks for your answer
