Jolla C2 Cover / Wallet
I have just bought 2 pre-order tickets for the Jolla C2 phone.
Does anyone know if it’s bilt on a existing Reeder phone? I wan’t a cover or wallet for my phone, so I can protect it for bumps and scratches :slight_smile:
There are various posts on the forum mentioning that this is a Reeder S19.
Search query
Looks like there’s some choice
Q: Accessories, screen protectors, cases?
A: Yes, we also like and need these indeed! Thanks to our partnership with Reeder this is now very feasible and relevant accessories will be added to the shop in due course - stay tuned!
https://forum.sailfishos.org/t/sailfish-community-news-23rd-may-2024-jolla-day-2-recap/18634
Although a bag and not a bump cover, I can warmly recommend the “flip” by Mapbagrag (old Jolla partner from the Jolla Tablet days), it is tailor-made (just mention “Reeder S19” in the appropriate text field) and made out of Tyvek, a synthetic material with a paper-like feel: https://mapbagrag.com/Handy/ (in German, but they send to most of Europe).
I’ve used a “flip” for many years with my Jolla Phone, the prior still looking flawlessly today (and not because I only used it with velvet gloves during those years).
I don’t see how that would be any better than my pocket…
No one said it would be.It’s just that some of us prefers another solution.
I also suggest keeping your phone in your pocket 24/7. :wink:
Well, I personally carry smartphones either in the pockets of my jacket (not the pants, due to a) uncomfortable and b) unnecessarily close proximity to the swimmers), in a backpack or simply in my palm, all locations where a phone can drop to the ground and/or get scratched by foreign objects, where a bag comes in very handy. I also like to use such a bag as a pillow while I’m actively using the phone, when I want/need to put it on the ground, on a table or on a dashboard temporarily, so the back of the phone doesn’t get direct contact with dirt and/or abrasive materials.
Tinfoilhattery.
Prime location, indeed - and prime dropping location too. But a bag makes the phone not very useful.
So when i would be at most risk of dropping it, it would not have any protection if i was to use a sleeve.
I’d be interested to understand more on this subject.
@meegouser is the one making the (rather dubious) claim, so take that up with them if you want to inspect the sources.
But take that in another thread please.
Found a leather wallet cover for Jolla C2 that fits quite nicely.
You have to cut hole for phones cable on top and small extra cuts on the right side for speaker up/down and power buttons.
It’s WAVE BOOK CASE (KOTELO in Finnish) made for Galaxy A05s. Sold in Finland at Prisma stores 19,95 €.
Made in China but Finnish Design.
Bat. Power Oy, www.batpower.fi
+1 for Samsung A05s case. I noticed that there covers where the casing part is harder, and covers where it is a bit softer and can be a little flexible, allowing one to fit the phone into casing a bit easier.
I imagine that with a very hard casing, getting the phone inside might be a bit of a bother. But a A05s cover with a slightly softer and a bit bending casing, Jolla C2 fits quite nicely.
In Finland, I found that at least A05s wallet cover from brand Screenor, is a nice cover where Jolla C2 fits suprisingly well. Side buttons can be used, and USB-C port is well available. Though, one has to drill a hole for the 3,5mm audio jack. I think most phone operators sell these. One example:
Also, a wallet cover for A05s by a brand Ferrelli seemed like the phone could fit well into it. Too bad, I wasn’t allowed to test it completely without buying, as a cable tie used for attaching the cardboard of the product prevented fully inserting the phone into casing.
I wanted a more premium case for my C2 and I got a good enough looking TPU case for A05s as recommended here. The case itself is made from TPU with some harder material on the back. Have to say that it indeed fit pretty well. I had to make 2 modifications to it to fit the C2 perfectly. First one was to enlarge the hole for power button, as it was constantly pressed. The second was to drill a new hole for the 3.5mm jack. Everything else (USB, volume buttons, speakers) worked fine without any touch-ups
Indeed. The plastic back cover that Jolla sells is marked with “S19 Max Pro S”, referring to the Reeder phone of that name. Any cover for that Reeder model will fit a Jolla C2.
