Jolla C2 Benchmarks
TLDR: The phone feels slow. Running tests to determine how much slower than the android version. Just for curiosity!
As I have used my C2 a bit now it kinda feels slow. Of course this is expected as the hardware isn’t even near anything exceptional. But as a curiosity I thought I’d run some benchmarks. First the easy ones in AppSupport Android and then later if I can think any in Sailfish native.
Mostly as time moves on and updates are applied it is interesting to see if anything changes.
Geekbench. I ran the latest version and compared to a run made on Android native version I found in geekbench database.
https://browser.geekbench.com/v6/cpu/compare/8526578?baseline=9004709
I’ll add more as I have time to do them. Just thought I’d share if anyone finds them interesting.
Important to not that the benchmark is run within AppSupport, so will reflect behaviour of that, not Sailfish OS.
In terms of Battery-Usage the Jolla C2 performs for me like this:
All Apps closed, Android-App support off and Flightmode on ~0.22%/h
All Apps closed, Android-App support on and Flightmode on ~0.64%/h
Apps open, Android-App support off, WLAN and Mobile Data on ~1.3%/h
Apps open, Android-App support off, WLAN, BT and Mobile Data on, Streaming Music with Jolla Mediaplayer to BT-In-Ears ~3.5%/h
Measured with SysMon.
On my typical usage the Battery lasts ~2 Days (100% - 10%).
Yes as I stated in the post that these are in the appsupport only. I have to have a look for some terminal cpu benchmarks which could be easily ran on sailfish native. Would be interesting to see how AppSupport affects the perfomance.
Ooh that is a great idea to include those too! Thanks
C2 's battery isn’t bad, but I realised the last 15% runs out quite quickly. Although battery saver kicks in.
Yes, seems to be model-specific or they use a weird battery-calibration algorythm. I am happy with the 2 days battery running under my daily heavy usage.
