Jolla C not charging
Hi,
I have a Jolla C that I’m no longer using as primary phone, so I was playing around and trying to disable everything I don’t need to prolong battery life and seems like I messed up something. My hope is that it is a software issue, I was messing up with mcetool. Now my Jolla can’t be charged. Whenever I plug in charger (tried multiple cables and multiple chargers) nothing happens. I can take battery out and charge it separatelly, but it is really inconvenient. It doesn’t charge even when turned off. Does anybody has any idea what could I do wrong? It might be a weird coincidence - that something died hardware-wise in the phone just as I was messing with mcetool, but I hope it is just some wrong setting.
Or maybe an easier question, can somebody post me theirs working mcetool settings? Or is there a way to revert those to defaults? I can try to adjust it back if I knew what working values were and if I had taken a track of what I changed… :frowning:
On device, you can check out mcetool help with command - mcetool --long-help
Also, see Sailfish cheat Sheet; https://sailfishos.org/wiki/Sailfish_OS_Cheat_Sheet
Asp per the cheat sheet details on mcetool;
Reset all mce values:
`systemctl stop mce.service`
 `rm /var/lib/mce/builtin-gconf.values`
 `systemctl start mce.service`
I had an idea how to use it, but didn’t recall what I changed. Hmmm, this way of resetiing seems pretty stright forward, but also looks like something Factory reset will do :frowning: Will try once my battery charges again, thanks!
Try fixing or changing the charging port. If the problem prevails kindly sell it to me. I really need one
