A quick question (or maybe a thread for additional questions if there are any):
Does the app only uses the on device microphones or it is supposed to work with a BT headset (record from the mics there)?
I seem to recall it using a wired mic when testing it out earlier.
But be advised that the Xperia 10 II can’t make use of mics in wired headsets in this release.
Thanks. I don’t have a 10 II and my phone doesn’t even have a headphone jack. So its on device only as it seems.
I’d like to see the app give you an option on what mic to use for recording, and maybe what codec to use for the recording. .wav is ok of course.
