Issue with 5.1.0.7 Early Acces update
REPRODUCIBILITY: Always
OS VERSION: 5.0.0.77 to 5.1.0.0.7
HARDWARE: X10II
UI LANGUAGE: EN
REGRESSION: NO
Updated to 5.1.0.77 and I had to force reboot after the update but system does not start. It boots to inactive password keypad and then after 2-3s the screen goes black and that’s all. I see black screen and white diode.
Working 5.0.0.77
Update to 5.1.0.7 Early release
Working phone,
Inactive keypad during boot and the black screen.
All
Black screen.
I’m looking for the hints what to disable in recovery mode to successfully boot. So far I have removed anything not from Jolla from /etc/systemd.
Updated to 5.1.0.8 and no change.
Why don’t you post in the release thread like everyone else? It’s not like the problem is unknown…
I have posted but there are 211 posts already and no one is going to read the post from 2 days ago.
So what do you mean that this whole new thread adds at all?
So what do you mean that your comments adds at all to this issue?
That people might be reminded that cluttering up the forum just wastes time and effort.
I am the last one that cluttering the forum and you fighting this undoubtedly a problem, are already doing the same and wasting my time and effort.
I believe that this issue is unique and after 2 days of solving I simple need any clue and direction where to search.
I have connected keyboard via USB and entered blindly pass code. The phone booted and I saw a SFOS lock sceen after entering pass code the screen then went black again.
Now I can login to system via wifi and ssh.
After restarting of homescreen systemctl --user restart lipstick I can see a login screen again for several seconds and the it goes black again.
Edit: It is getting interesting, as long as I use touch screen e.g. rotate login screen carousel it works. After entering pass code or living it alone for a few seconds the screen goes black.
Sounds like an incomplete update. Is there any space left on the root partition?
A lot:
Filesystem Size Used Available Use% Mounted on /dev/sailfish/root 10.2G 6.6G 3.6G 65% /
Have you tried the verify option from sfos-upgrade?
Or looked at some logs?
Back in business. I have fixed the issue.
The culprit was pulseaudio that was unable to start due to wrong libgcrypt library in /usr/lib64.
There was libgcrypt.so.20.7.0 file linked to libgcrypt.so.20 and libgcrypt.so.20.7.0 file.
I have removed libgcrypt.so.20.7.0 and relinked libgcrypt.so.20 to libgcrypt.so.20.7.0.
I have no clue where the libgcrypt.so.20.7.0 comes from.
It looks like it was a part of orphaned package:
Information for package libgcrypt20:
Repository     : @System
Version        : 1.12.0-1.2.3.bso
Arch           : aarch64
Vendor         : meego
Installed Size : 1.1 MiB
Installed      : Yes (automatically)
Status         : up-to-date
Source package : libgcrypt-1.12.0-1.2.3.bso.src
Upstream URL   : https://www.gnupg.org/software/libgcrypt/index.html
Summary        : The GNU Crypto Library
Description    :
    Libgcrypt is a general purpose crypto library based on the code used in
    GnuPG.
most likely fetched from one of testing repositories.
