Is there any way i can setup the hotspot function to a specific wlan channel
Hello!
I have a router with WDS and want to use it with my Sailfish OS Hotspot option but i canţ find were i can set the channel, this is requiert by the router: “Make sure that the wireless router and the access point (Sailfish) intended for the connection use the same channel.”
Thank you!
Looks like it might be possible once connman gets updated as it seems to support this now since October:
https://git.kernel.org/pub/scm/network/connman/connman.git/commit/?id=3a33f2eb490180001735616716dc7fa0819cc8a1
Thank you for your answer
Now I have the same problem and continue here to not double post/thread.
My impression is that all SFOS Mobile access points seem to transmit on channel 1 in the 2,4 GHz band. I want to force the Mobile access Point to another channel. No need to change this frequently in a menu available in the settings, so no need to change much code to add a new menu item. An option to tweak a config file by CLI & vi editor to change the WIFI channel is full sufficient for me.
In what file is the current transmitting channel of the Mobile Access Point defined?
Or, can I change the channel using a CLI command as devel-su?
Thanks for any help!
