Is Slumber maintained?
Hello!
Slumber is very handy app, especially with Talefish. I like this app very much. So does anyone know is Slumber maintained anymore?
At least the sources are available: GitHub - jgibbon/slumber: slumber sleep timer for SailfishOS · GitHub
But indeed it sounds it’s not maintained anymore
Well, the question is, does it work? It may not have received much attention if it just works?
Are you able to translate it or have you already?
If you did a translation file in the .ts format, you could just try to submit it to the github repo and maybe the author will wake up from the slumber.
I use Slumber with audiobook/podcast player Talefish, which works nicely.
Both are available in the Jolla store, but those versions don’t integrate and Slumber used on its own seems to crash when the manually started countdown runs out.
What works for me is getting Talefish from Openrepos and Slumber from Chum.
