Hi,
I was wondering if I can change locale settings on an per app basis for Android apps.
Background: I have device locale setting set to en_UK for language, but time/currency/number format I’d like to be german.
So far I had no issues with Sailfish apps, but some Android apps only recognize en_UK as locale and use it for all formats.
Can I change that for specific apps?
Generally speaking, you can temporarily change the locale for any application on GNU/Linux, like this:
LANG=de_DE.UTF-8 sailfish-browser
I’m not sure if that applies to Android, too.
That doesn’t work unfortunately.
Sorry, this is a bit off-topic but somewhat related:
I recommend en_IE
instead of en_UK
when setting l10n env vars, as that solves the currency part.
(Of course, English(Ireland) is not a supported lanuage in SFOS).
To just adjust output of dates, currency, and numbers, the variables LC_TIME
, LC_MONETARY
, and LC_NUMERIC
can be used.
Also, if you like ISO dates, you can use LC_TIME=en_DK
or (for GNU utilities) TIME_STYLE=iso
Back on topic, does setting the language in android settings to ‘English(Germany)’ work?
If I knew, how to change locale settings for Android, I could tell you. As far as I can see, Android has no seperate settings for locale, it just takes the same locale as configured in Sailfish.
But I’ll try en_IE
as default system locale.
