JPEG is a lossy Picture-Format. Everytime you save it again, you loose Picture-Information. Compression-Artefacts will be more seen and Image will be more blurry and it will shrink in Filesize.
Also the Size of a JPEG-Picture is depent from the content, try it out. Big Areas with same Color result in smaller Filesize, so also often dark Pictures. Its all up to the Packing-Algorithm and the choosen Compression-Rate (100% Quality = No Compression = No Content-Loss = Big File, 0% = Color-Swamp = Much Content ist lost = Very small File
So maybe its better to save a edited JPEG-Picture in a non Loss-Format like PNG…etc or set the JPEG-Compression-Rate between 100-90%.
