Hi,
My unused Aquafish went to ‘Recovery mode’ and now I want to telnet it but it is asking me the devlock code which I am not sure. As the phone not in use I am planning to install the latest saifish os. Please help me out.
Thanks,
Kiran Teki
Hi,
Thanks,
Kiran Teki
I am able to recover it and restored successfully. Now try to upgrade to 4.x using CLI with below instructions.
ssu release 4.2.0.21
version --dup
reboot
But thows below error after nine attempts seems to be non-availability of repo. Any help would be much appreciated.
Error : file;//repodata/repomd.xml not found
Did you obey the stop releases.
Or, wait…
Is the AquaFish supported at all anymore? Or is is it Jolla C-fied?
Else this might block you?
Updated stop release 2.2.0.29 now progressing 3.0.0.8. We will post the updates.
Mind the additional stop release (2.0.5.6) for the Jolla C / Intex Aquafish, which Jolla does not list.
Or simply use sfos-upgrade, which takes care of that.
Yes, the update is 3.0.0.8 still not completed as hanging up with many ‘time out’ errors and sometimes caching won’t work. When a timeout error happens I terminate it by pressing ‘Ctrl-C’ and again when started says ‘Cache waiting’.
Is there any fix to make it faster as it is eating all my time?
Thank you @olf for the response.
Let me give you the background of the problem. Actually, I stopped using it in 2019 as my office work require the ‘Okta verify’ for MFA hence I brought the Android phone and recently I lost it so I came back to SFOS.
My main requirement is ‘Okta verify’, VolTE and android apps, if this those works properly then I am happy to use it and NO NEED of any other android phone :).
So help would be much appreciated.
Update is 3.0.0.8 completed and started 3.2.0.12 update but getting ‘‘Error: this request will break your system’’. Any fix or any automated script that makes things quickly?
i was able.to update my jolla-c ied intex to 3.2 or 3.4 but:
you expect volte to work and it.still does not…
Hopefully you are using sfos-upgrade for this process as previously advised since for example gives you prompts such as:-
[root@Sailfish Documents]# sfos-upgrade
Notice: Less than 1 GiB (881452 KiB) free space on the root filesystem!
Please consider to clean up or enlarge the root filesystem, see e.g.:
Whilst updating a Jolla C to 4.3.0.12 this morning there were a couple of time-outs upon server connection on one of earlier stop releases. As Jolla C had been reset long the way, I could ignore the < 1GB free space and updates proceeded without issue
In order to use’ sfos-upgrade’ it must be available on the target phone, so how to install that first?
I got it, mine is still Aquafish 3.x so can I upgrade or it only supports Jolla C ?
Finally trying upgrade with ‘sfos-upgrade’ but no luck.
REFRESHING CACHE AND DOWNLOADING PACKAGES
Resolving: 100%
Error: This request will break your system!
Finished transaction (status=2, runtime=73876ms)
UPGRADE NOT COMPLETE - Retry 2 of 9
Waiting 3 seconds before retry.
Is there any space issue ?
[root@Sailfish nemo]# df -h
Filesystem Size Used Avail Use% Mounted on
rootfs 2.4G 1.2G 1.2G 51% /
/dev/sailfish/root 2.4G 1.2G 1.2G 51% /
/dev/sailfish/home 11G 619M 9.7G 6% /home
devtmpfs 938M 176K 938M 1% /dev
tmpfs 952M 360K 952M 1% /dev/shm
tmpfs 952M 14M 939M 2% /run
tmpfs 952M 0 952M 0% /sys/fs/cgroup
tmpfs 952M 4.0K 952M 1% /tmp
tmpfs 952M 0 952M 0% /mnt/obb
tmpfs 952M 0 952M 0% /mnt/asec
/dev/mmcblk0p1 64M 48M 17M 74% /firmware
/dev/mmcblk0p21 682M 676M 0 100% /fimage
/dev/mmcblk0p23 223M 43M 176M 20% /mnt/vendor_data
/dev/mmcblk0p22 28M 112K 27M 1% /persist
tmpfs 191M 560K 190M 1% /run/user/100000
Hi,
Although @peterleinchen asked whether your Aquafish has been modified with coderus Jolla C script you did not directly answer him. If it has NOT been modified then this resource explains your issues and why warning of “will break your system” has been given: https://together.jolla.com/question/204796/did-anyone-manage-to-update-an-intex-aqua-fish-or-jolla-c-to-release-3038/?answer=205948#post-id-205948
Upgraded AF , “release” shows 3.0.0.8 but “version” shows 2.1.4.14, although I didnt even update to 2.1.4. ssu lr shows all repositories of 2.1.4. Did factory reset and upgraded through cli to 3.0.0.8 but backup hanged at Gallery. Now Backup shows “Cannot load page” and OS keeps telling Update 2.1.4 available, and also Storage running out, when theres ample storage since ive only just upgraded and backup didnt work.
@hk, I hope you did follow and read the links provided by peterleinchen’s post and aspergerguy’s post in this thread, to which I might add this specific one: Did anyone manage to update an Intex Aqua Fish or Jolla C to Release 3.0.3.8? [closed] - together.jolla.com
Yes, I’ve read all those. Seems “Jolla C -fying” would be the last resort, however, it is quite convoluted and also the links for downloading images are no longer working. I’ve had the AF since 2017… but now with it no longer updating, time for a new android ( :’). I only wanted the contacts and sms restored. Got contacts because its a simple vcf. But dont know how to get sms from the DUMP file in the backup.
