Integration of internxt.com
Dear Jolla, would you consider integrating more cloud storage services, such as https://internxt.com/ for example? See also Getting Started with Internxt | Internxt Help Center.
ps- If possible at all… ?
Wait until Internxt have implemented WebDAV:
Internxt WebDav support | Internxt Help Center
At this time, we’re currently working on implementing WebDav support as well as other integrations. At the moment is not possible to integrate WebDav, FileZilla, WinSCP, or CyberDuck.
and then follow this Guide (Mount WebDAV-Resource with DAVFS2):
https://forum.sailfishos.org/t/guide-mount-nextcloud-webdav-folders-locally-with-davfs/8038
Thank you for the quick response!
