Im using manjaro linux and run the batch file and get
Detected Linux
Searching device to flash…
Found 1 devices: CQ3001NU4F
Fastboot command: fastboot -s CQ3001NU4F
Flashing boot_a partition…
Sending ‘boot_a’ (20020 KB) FAILED (Status read failed (No such device))
fastboot: error: Command failed
what am I doing wrong?
did you unlock the bootloader before?
Yes bootloader unlocked. I was finally able to flash in windows by disabling driver signing. Sailfish X is working now.
On Linux, I was able to unlock and flash it with newest platform-tools from Google.
Stock ones in Ubuntu didn’t work.
mankir
21 September 2021 17:15
7
you have to add your user to the plugdev group and may be add the vendor and device hex string to the usb rules section of your distro.
answer to your question: you don’t have write access to the device!
