what would you do in this case? `LC_ALL=C devel-su zypper in qt5
-qtgui-devel
Password:
Loading repository data…
Reading installed packages…
Resolving package dependencies…
Problem: This request will break your system!
nothing provides pkgconfig(android-headers) needed by libhybris-libEGL-devel-0.0.5.42-1.3.3.jolla.aarch64
Solution 1: Following actions will be done:
ignore the warning of a broken system (requires:droid-hal-version-xqau52)
ignore the warning of a broken system (requires:libhybris-libwayland-egl)
ignore the warning of a broken system (requires:libhybris-libEGL)
ignore the warning of a broken system (requires:libhybris-libGLESv2)
deinstallation of libhybris-libEGL-0.0.5.42-1.3.3.jolla.aarch64
deinstallation of libhybris-libGLESv2-0.0.5.42-1.3.3.jolla.aarch64
deinstallation of patterns-sailfish-device-adaptation-pdx201-0.1.15-1.7.2.jolla.aarch64
deinstallation of libhybris-libwayland-egl-0.0.5.42-1.3.3.jolla.aarch64
deinstallation of qt5-qpa-hwcomposer-plugin-5.6.2.18-1.3.1.jolla.aarch64
deinstallation of patterns-sailfish-device-configuration-xqau52-0.1.15-1.7.2.jolla.aarch64
deinstallation of droid-hal-version-xqau52-0.0.1-1.3.15.jolla.aarch64
Solution 2: do not install qt5-qtgui-devel-5.6.3+git43-1.11.1.jolla.aarch64
Solution 3: break libhybris-libEGL-devel-0.0.5.42-1.3.3.jolla.aarch64 by ignoring some of its dependencies
Choose from above solutions by number or cancel [1/2/3/c/d/?] (c):`
also on freebsd? and why can’t i compile on the phone for the phone when i can compile on the pc for pc? after all the phone is also a computer and has even a better processor
FreeBSD is not a supported operating system for our SDK. Perhaps you could e.g. run Linux in a virtual machine?
It’s definitely possible to compile on the phone as well, I know that there are people who do it. I still don’t recommend it though, especially if it’s your daily driver. And it’s not a scenario which we support.
