Hi!
I am not sure since when, but around last update, Android apps write that they don’t find a (compatible) version of Google Services. But MicroG is still installed…
do you have an idea on how to fix this?
Hi!
How did you install MicroG? There is an option to check if it’s configured correctly.
In the settings of your phone, did you enable the option “Disable Android App Support system package verification”?
Thx…indeed the setting has been switched off.
