REPRODUCIBILITY: 100%
OS VERSION: 4.5.0.19
HARDWARE: Both 10 III and XA2 Ultra
UI LANGUAGE: Polish
REGRESSION: It seems to have been introduced in 4.5.0.16
Battery % in Android Support is correct only upon Android Support start. Then it never gets updated.
None.
- Launch Android support. Go to e.g. Android Settings / Battery, or to any other place or any Android app showing battery % level. Compare it with the Sailfish OS side, they are the same.
- Wait some time until battery % drops as displayed on the Sailfish OS side.
- Compare it with battery % shown in Android support. It is wrong. It should have decreased by the same amount as on SFOS, but it didn’t change at all since Android support launch.
Battery % changes should be updated in Android support the same way as in SFOS. Both should be showing the same battery level.
In Android Support correct battery level is shown only right after it was started. Then it does not get updated.
None.
It is the same on both my 10 III and my XA2 Ultra.
The following screenshot shows different battery levels shown simultaneously by SFOS and Android support (it was taken when screens where in the middle of being switched, so they are translucent):
