Improve description for option "Ringtone for incoming calls"
If Do not disturb and Ringtone for incoming calls are on, this will happen:
  • Vibration if Silent is on
  • Ringtone if Silent is off
Which is logical somehow, but the description is not clear. Could be neat to get something dynamical. Like:
  • Allow some incoming calls to play vibration as exceptions to ‘Do not disturb’ mode
    • If Silent is on
  • Allow some incoming calls to play ringtones as exceptions to ‘Do not disturb’ mode
    • If Silent is off
what are “some” incoming calls? (edit: probably the favorites?)
I don’t understand your question
I dont know which calls are meant with the term “some incoming calls”, probably the calls from the contacts set as favorite?
Still not sure to understand what you’re asking, but I understand following:
  • If On: ringtone or if silent do vibrate
  • If Off: do nothing
  • If Only favourite contacts: if incoming number is a favourite contacts, then ringtone or if silent do vibrate
  • If Only contacts: If number is in the contact address, then ringtone or if silent do vibrate
I’ll switch language to english maybe then i can describe better what exactly i mean
Still don’t understand what you mean :frowning:
Now I understand, i never clicked there and never saw the options. I also didnt realize if i set do not disturb to “on” the phone still rings (as default setting).
