Is there any Hardware Acceleration available in Sailfish OS? One example: watching videos. It seems that the CPU is en/decoding the video -> high battery usage. Why is this not done by the GPU?
I like to watch YouTube etc on my phone - on Android there is no problem, I can watch videos for hours. But on Sailfish there is such a huge battery % decrease that I only can watch a few videos. Is there any solution for that?
I have noticed a similar issue (poor performance above 360p) and posted a workaround on TJC.
I got the impression that hardware acceleration for vp8/vp9 codecs was mentioned in the release notes at some point, but the still poor performance suggests that it doesn’t apply to the browser.
(I’m running an Xperia 10)
That’s amazing!
I’m dropping the majority of frames already at 720p vp9, whereas 720p h264/avc1 is super smooth.
(There is only 360p and 720p for h264)
It seems @emva has it working on the Xperia X though?
So maybe someone forgot to enable it on the newer devices, or i misunderstood the release notes…
Having “media.webm.enabled” off, i dont have the choice of higher than 720p; then avc1.64001F ,mp4a.40.2 (22) is being uses as codec.(still smooth)
That being said, a long time ago i went through about:config “for fun” and enabled / disabled some stuff.
Is there any way to reset the about:config settings back to stock?
Hi,
I also experienced lags while reading videos into the stock SFOS media player.
I have tested several resolutions codecs and frame rates but I couldn’t get rid of them.
Have somebody found a solution since the last posts?
(Xperia XA2, SFOS 4.3 free)
