Hiya,
the the Austrian government app currenrly working?
Thanks in Advance,
Raphael
Hiya,
Thanks in Advance,
Raphael
I could install it on my X10-II where micro-g is set up, but it asks for a security code ![]()
That means itâs complicate. You should ask your government to remove this âsecurityâ. Check this thread for further information: Unable to set lock pin for Android apps requiring it - #52 by soulsource
Hi!
You can also use ID Austria without the app. For example, check out this tutorial: How To: ID Austria ohne Zwang - epicenter.works
Own experience - I use IDAustria with a FIDO key, no connection with phone, and it works. It is a bit cumbersome, but as usually one doesnât need it too often, itâs acceptable.
Thanks, good to know. Now I only hope, that Raiffeisen works as well somehow ![]()
Thanks, does such a key work with Linux as well?
Iâm sorry, canât tell you with certainty.
I was not able to register austriaId but i do not want to have it on the phone anyway
I have a fido instead.
Easybank now enforces fucking app and this works on C2
Should, i will have to try it out soon as i am drooping my last windows pc.
Will report then
UPDATE: you do link the fido token not the laptop.
so switching the laptop from windows to linux is from token perspective completely irrelevant
For id austria there are two apps available. The id austria app which is complaining on ânon standardâ devices and the app handysignatur which is working for me. it is the old app but nowadays its working with the full id austria too.
ID Austria with FIDO2 tokens works with Linux, too, yes. A-Trustâs document signing software for ID Austria PDF-Over supports Linux with FIDO2 tokens as well.
I did setup the following Fido2 key which does work well:
https://www.alza.at/gotrust-idem-key-usb-a-nfc-d7108704.htm
Fido functionality in Linux appears to rely entirely on your browser. In order to use your Fido2 key for ID-Austria you need to set a pin code for the key first. I could not figure a way how to do it with Firefox but Chrome and Chromium browsers should support that feature. The former is probably not acceptable for many (and it isnât for me) so I chose Brave browser for that.
Enter:
brave://settings/securityKeys
in the address bar, while your key is plugged in and you should get to a menu where you can set a pin key. This can be also done on another system than the one youâd like use your key then.
Once your Fido2 key has a pin-code you can also use Firefox to set it up. See also here:
PS: Your ID-Austria account has to be extend every 5 years. This can be done with the app but I have not found a way how to do it with the key. It could be that extending requires some more cumbersome method if you donât have an app.
I guess that the original problem is still not solved?
I was able to install and set up the app. You get a warning about a bootloader, but you can proceed at your own risk. Unfortunately, I cannot set up the app further because an Android lock pin is required. I havenât managed to set it up yet.
I have the same with a banking appâŚbut seems to have worked in older minor versions
you can install a patch from openrepos to enable setting the lock pin in android support
which one? I found this, but on Jolla Phone 2 it doenst install
yes this one. oh no. in a few days i will have my jolla phone too, then i can check that
it wasnât working anymore, but i found a solution Appsupport15-gatekeeper-pin-enabler-patch | OpenRepos.net â Community Repository System
