I’m recently being regularly called by an automated range of ‘call and hook’ number.
They call, you pick up the phone and they’ve hung up.
I want to block these calls and I’ve heard phonehook can do the job.
But when I enter a number in the call blocks section, it’s not saved.
And the ‘start daemon’ button isn’t doing anything.
The user nemo is hard-coded so
ln -s /home/defaultuser /home/nemo
- disable Sailjail in the .desktop file
- stop Phonehook (pkill phoneh)
- start Phonehook
- start the daemon
Use wildcards when blocking - I block 100 numbers for each unwanted call.
My SIM is in my XA2 so I can’t verify if Phonehook actually works in 64-bit Sailfish, but at least the daemon is running.
I haven’t done any coding in Sailfish in a long time, so it’s…
devel-su ln -s /home/defaultuser /home/nemo
and then how do I disable Sailjail? Which .desktop file?
/usr/share/applications/phonehook.desktop
[X-Sailjail]
Sandboxing=Disabled
