I have found (with ChatGPT assisting
) another way to achieve the same result. Might be interesting to someone…
This was tested on my Jolla Phone (2026), Android AppSupport 15, with a Murena Fairphone 5 as the primary phone. (Yes, a degoogled phone!
Open the Jolla terminal and execute:
devel-su appsupport-attach /system/bin/sh
3. Temporarily switch to tablet-sized display mode
wm density 260
On the Jolla Phone (2026), this increases the effective smallest display width beyond Android’s typical 600 dp tablet-layout threshold.
4. Completely stop Viber
am force-stop com.viber.voip
5. Launch Viber again
Open Viber from the Sailfish launcher, enter your existing phone number, and follow the activation prompts.
Viber should now display a QR code for secondary-device pairing.
6. Pair with your primary phone
On your existing primary phone:
Open Viber.
Go to More and open the QR-code scanner.
Scan the QR code displayed on the Jolla.
Approve the pairing.
Verify that you can send and receive messages.
7. Restore the original display density
Return to the Android shell and execute:
wm density reset
Restart Viber from the Sailfish launcher.
On my jolla, Viber remained paired as a secondary device and continued working normally at the original 380 dpi density.
