Hey, weird question: how to turn off sound
telegram notifications ? Ive disabled everything in telegram itself but it still makes sounds! Is there anything I can do on SFOS side to completely mute it?
Are you using the Android application? Or one of the Sailfish OS applications, like Depecher, Telegra’me or Fernschreiber?
Android, mostly because no one of native is mature enough… Btw, I haven’t heard about Fernschreiber - need to check, thanks.
Under Sailfish settings, apps, telegram, android settings.
Also use aliendalvik control, (from openrepos), go to sounds, advanced and disable everything there.
