How to shrink /home-partition on Jolla tablet?
Hello all,
on my Jolla tablet (yes, I got one) I cannot update OS anymore.
It says, there is not enough space on /root. I have so much unused space on /home, so I want to shrink this to maybe 30G and increase the root partition than.
Is there any possibility to shrink the /home fs/partition?
Normally it is only possible with unmounted filesystems, but how can I unmont? User nemo is always logged in, so device is busy.
Thank you,
Schultze
OS-Version is 4.5.0.24 now
There is a how-to by @olf for resizing root on xperias: olf (Olf0) (Olf0) / SailfishX on Xperias · GitLab
You would need to figure out the numbers for the jolla tablet memory.
The “numbers” are very likely the same, and there are some “numbers” to check in the first place to ensure that, as mentioned in the guide: The original root partition should comprise 625 extents of 4 MB (see section 3.3.2, point 7).
Thank you for the hint.
It worked.
