How to restore backup from another device?
Is there any way to restore a backup made from another device? Unfortunately I need to switch back to Android on my Sony Xperia X (banking and other android apps not working any more), but I would like to keep up with Sailfish OS development with my old Jolla 1 and it would be great if I could import my data (especially Notes and Messages) from the Xperia X.
There are some scripts on together which can backup and restore messages and messaging history.
I haven’t used these methods for a while so not sure which ones work reliably, but here it goes:
Thank you @nephros, I managed doing it manually using a mix of tools: commhistory-tool for calls and messages, sqlite3 for notes and a file manager / cp command for Gallery files.
When I was switching Sailfish devices, I made a backup to SD card, then moved that SD card to new device and restored backup from it.
@ender That works well indeed, except for MMS images which are not included.
I remember moving from Sony X to 10 back in march, and all my phone calls and sms lost the SIM slot # field parameter. Did anybody investigate?
I would precise, at least for the first method linked
to check after copying ~/.local/share/commhistory/ that the permissions of the folder and files inside are drwx------ with defaultuser as owner, and privileged as group.
