How can I install DeadBeef Silica on 5.0.0.62 on a fresh flashed Xperia 10? It’s not visible in Storeman and manual installing of the .rpm file doesn’t work.
It reports 2 missing libs:
libaudioresource-qt.so.2 and
libFLAC.so.8 .
Where to get these libs and manually install it before trying to install DeadBeef Silica again?
libaudioresource is available in the package libaudioresource-qt-2.0.2-1.6.1.jolla.aarch64, but the flac library is at soversion 12 meanwhile. You could try symlinking, it may work.
[root@Bastel defaultuser]# pkcon search libaudioresource-qt
Suche nach Details
Starten
Software-Liste wird aktualisiert
Abfragen
Fertig
Installiert libaudioresource-qt-2.0.2-1.6.1.jolla.armv7hl (installed) Sailfish OS Audio Resource API (Qt bindings)
Verfügbar libaudioresource-qt-debuginfo-2.0.2-1.6.1.jolla.armv7hl (jolla) Debug information for package libaudioresource-qt
Verfügbar libaudioresource-qt-debugsource-2.0.2-1.6.1.jolla.armv7hl (jolla) Debug sources for package libaudioresource-qt
Verfügbar libaudioresource-qt-devel-2.0.2-1.6.1.jolla.armv7hl (jolla) Development library for libaudioresource-qt
Verfügbar libaudioresource-qt-example-2.0.2-1.6.1.jolla.armv7hl (jolla) Example application for libaudioresource-qt
I tried to install available packets but without success.
[defaultuser@Bastel ~]$ devel-su
Password:
[root@Bastel defaultuser]# pkcon install libaudioresource-qt-debuginfo-2.0.2-1.6.1.jolla.armv7hl
Auflösen [ ] (0%) Paket nicht gefunden: libaudioresource-qt-debuginfo-2.0.2-1.6.1.jolla.armv7hl
Ausführung des Befehls fehlgeschlagen: This tool could not find any available package.
[root@Bastel defaultuser]# pkcon install libaudioresource-qt-debugsource-2.0.2-1.6.1.jolla.armv7hl
Auflösen [ ] (0%) Paket nicht gefunden: libaudioresource-qt-debugsource-2.0.2-1.6.1.jolla.armv7hl
[root@Bastel defaultuser]# pkcon install libaudioresource-qt-debuginfo-2.0.2-1.6.1.jolla.armv7hl (jolla)
bash: syntax error: unexpected "("
[root@Bastel defaultuser]# pkcon install libaudioresource-qt-example-2.0.2-1.6.1.jolla.armv7hl
Auflösen [ ] (0%) Paket nicht gefunden: libaudioresource-qt-example-2.0.2-1.6.1.jolla.armv7hl
