How to have my Nextcloud photos synced to Jolla Phone?
Hello! :smiley: I’m just starting to configure and use my Jolla Phone. I’ve added my Nextcloud account. While contacts synced perfectly, I see an empty Nextcloud item in my gallery, no photos are downloaded though.
I have enabled photo sync in the account settings on the phone and set the interval to 15 minutes, but nothing is downloaded still. How can I get my photos from Nextcloud accessible on a Sailfish device?
I have sync set up both ways on my 2026 and it occured to me that it depends on the folder naming. I believe that only the photos directly in /Photos (?) are synced. I have a fairly confused structure and MOST of my photos are not synced.
the directory structure that seems to get auto synced is: /index.php/apps/photos/folders/Photos in my case.
EDIT: I also do intentionally (using rclone) sync from the phone to nextcloud into another directory structure. That’s backups that I don’t want to see in the Gallery AND the nextcloud directory. So, the way I use this is to push files from desktops to /Photos so they show up on the phone, but push photos from the phone to nextcloud to a subdirectory so they don’t get duplicate showing.
The Nextcloud account settings in SFOS have no option to do basic file synchronization.
You may use apps like Sailsync to setup file/folder synchronization, or use a more generic solution like rclone to have full control (this is what I am doing).
Files is what I expected won’t be possible with the default account, but I hoped at least for photos. I do have another folder name though, so probably I’ll have to find another way.
I’ll report a bug though.
EDIT: It looks like Sailsync requires installing some custom libraries from Chum due to dependency problems… this is what I don’t want to do. I intend to use Sailfish rather like a normal user would, without dealing with libs or terminal.
Ferry Sync looks promising though.
Yes, Ferry Sync should be Fine for your use case —> if something does not work, just ping me :joy::joy::sweat_smile:
I tried Ferry Sync, but eventually returned to Nextcloud Android app and images in gallery. Reasons:
  • I use Nextcloud Notes, and at least ownCloudNotes doesn’t seem to support checklists in notes – so I had to revert to Android client for now.
  • Nextcloud Notes required main Nextcloud Android app as well to operate
  • I don’t need to have photos only synced – have them just available remotely in the gallery is OK.
  • Still, neither allows me to view many of my photos from Sailfish, as they are in HEIF. Thus for now I’m sticking with Nextcloud app, but if I want an actual gallery app, I’ll need an Android one.
  • Also, I cannot sync my keepass file – I cannot select main Nextcloud folder as a sync target for a single file. Also, I cannot tell Ferry Sync to download a file to the given location and then keep it synced bidirectionally. That made me revert to Keepass2Android, because it takes care of synchronizing its DBs.
For Ferry Sync, here are my suggestions:
  1. Allow entering a non-yet-existing path for local file or folder (provided that the parent exists), so that in such case Ferry Sync starts the sync by downloading from remote first.
  2. Allow syncing a root Nextcloud folder if I want to have all the files synced with my phone or pick a file from the root folder.
With these two I potentially could try Sailfish native KeePass client again.
@Pioter thanks for the feedback - i will have a look into your points.
for yout first point, thats true, currently you need to download the single file first and than start the sync pair configuration. Thats also the workaround for now.
(Shameless self promotion) If you want to be able to use tasks in Notes, you may want to give Lappu - Nextcloud Notes on Sailfish OS a try :slight_smile:
Where can I install it from? I cannot find it in openrepos or Jolla Store.
It’s currently in Harbour’s QA, so if you don’t want to wait you’ll have to download it from the Release page (or via Harpoon if you use that)
With checklist support:
I will probably wait for it to land either in harbour or in openrepos and then give it a try. Thanks for showing :slight_smile:
Looks like a mix of the official app with Sailfish UX guidelines, which is promising. Are you still developing it thoug? I see the last commit from 3 years ago on GitHub.
