How to format a microSD card as separate storage?
Hey there, how would I have to format a micro SD card if I wanted to use it as separate storage on my JP26? I formatted a new card (via GParted on my laptop) to ext4 but when I had inserted it into the card slot and rebooted the JP26 I was shown a message saying the card wasn’t useable. The automatic formatting done when I had rebooted again was to vfat, and the card had been integrated as internal storage (although in my file manager (Fx) it shows up as Media Card). Isn’t there a way to keep the card as separate storage so I could use it to copy data from another device onto it and put it back into the JP26 to paste the data to the phone?
This sounds very weird. Automatic formatting and being added to internal storage is not a thing in SFOS. All SD cards are separate, regardless of format. Maybe some Android apps can manage to get confused, but i don’t really see how.
The solution, (long time ago, things might have changed) was to make two partitions.
A small vfat one, as first, and a second one, that I formatted on the device selecting the encryption option.
That seemed to have worked:
Had to unmount the card, format it from “storage” in settings, ext4 was possible there, had to mount the card again.
And, lo and behold, it stayed visible as a card, formatted with ext4. But in FX (file browser) I still saw two entries named “Media Card” of different size:
No. 1 had 178 GB free, 40 GB used (I have a 256 GB card), no. 2 had 233 GB free, 294 MB used - this latter entry is what it says in the settings app under “storage” as well. And that’s also where my sailfish_backup_2026-… has been stored.
So, I guess we can see this as solved. Thanks, folks!
This reads all so wrong!
@filip.k
Could you just remove this thread?
I guess he formatted the card wriongly and just misinterpreted the readings from that FX (file browser) thing, whatever that is!
The internal storage may be shown in other (Android?) apps as a SD card as well.
So first one was/is the internal storage and second one was/is the external SD card storage.
There is no automatic formatting!
And there is no “extensions of internal memory by inserting a SD card” Android-like-thing!!!
So, solution was that the formatted the card on the phone to EXT4:
It’s unclear to me as well. But i don’t feel like deleting it.
