How to fix a crashing 'Persons' (contacts) application?
Hi there, just switched to a Jolla CF2 and really enjoying it! Although I am getting stuck occasionally as a rookie to Sailfish / Linux. My ‘Persons’ application has crashed while I was entering contacts, and now it keeps crashing. I have tried to close the application and restarted the phone several times, but the issue remains. I tried to remove al contacts in the settings menu in an attempt to reset the application but that also did not solve the issue.
Does anyone know how I can reset the application? Your thoughts and help are much appreciated!
That’s odd. Did you import your contacts from a file or manually entering each one?
What about if you slide to “People” from Phone app?
I was entering them manually.
Going to People by sliding from Phone app still works, thank you so much!
Still weird that starting the application does not work. Do you know of a way to fix that?
Do you have enabled “Show contacts from SIM” in Settings?
Maybe will help if you try to change those settings there.
If not maybe contacts database is corrupted.
Really odd in any case.
I’m no db specialist but I would experimentally test the db in terminal, as root, with sqlite3:
sqlite3 /home/defaultuser/.local/share/system/privileged/Contacts/qtcontacts-sqlite/contacts.db “PRAGMA integrity_check”
It should answer “ok”
If you can reach contacts from phone app, most probably (100% :wink:?) the db is okay.
I had this a decade ago or so. But cannot remember, so I did a brief search on TJC
Maybe this helps already, else anyone else may still remember that?
