Continuing the discussion from Beta VoLTE on the Xperia 10 III, disabled by default:
hi @mbrazi_1 this is the thread to continue your question.
Hi @mbrazi_1
In this article it says:
- Note that there different usernames on the phone depending on the Sailfish OS version. On 3.4.0 or later, there are two possible usernames, nemo and defaultuser. Only the correct one works. You can check it from the prompt of the Terminal app on the phone or with the command below (before getting root rights).
@mbrazi_1 From putty, login with username âdefaultuserâ (or ânemoâ if itâs an old system) and when asked for password, type the password you setâ up in the phones developer options.
Once you are logged in as âdefaultuserâ (or ânemoâ if itâs an old system), type âdevel-suâ
When asked for password, type the password again as above.
Then youâre logged in as âadminâ.
If ready, leave with âexitâ.
Then you can close the terminal.
