How to auto forward sms
Hi,
I’m trying to forward SMS messages I receive on my Jolla phone to some other service like SMS on another phone, or whatsapp or signal,… The Jolla one is often left at home due to its weak battery.
Does anyone know of some tool or app I could use for this ? A search in the forum or app store didn’t reveal much so far.
I’m willing to use developer skills like ssh remotely into the phone or use some kind of advanced scripting. Unfortunately I currently don’t know much of what’s possible on SailfishOS in that regard. So all hints or ideas are welcome.
Thanks!
I don’t think there is an app that does exactly what you want, apart from KDE Connect (Sailfish Connect) which can do something like that but only on the same network. I does work fairly well though,
There’s this which can get you started on dealing with SMS from scripts:
https://together.jolla.com/question/54249/how-to-saving-sms-text-conversations/
HTH and good luck!
Thanks @nephros , that’s a worthwile starting point.
I didn’t realize SailfishOS was scriptable with bash. That’s very useful.
As I’m new to SailfishOS (I do have plenty of programming experience in general on linux), I still have a few questions that may be obvious to others:
  • The other post talks about connecting via ssh. What is the user to connect with and how do I set a password or (even better) a trusted ssh key ?
  • Is there an event system to tap into ? I am specifically looking for some kind of trigger I can use to run a script as soon as an sms is received.
  • Can an sms be sent from the command line in SailfishOS ?
Perhaps I should put these as separate forum questions…
SSH: https://jolla.zendesk.com/hc/en-us/articles/202004793-SSH-and-SCP-connections-over-USB-from-Ubuntu-to-your-Sailfish-device
SMS from comman line: https://together.jolla.com/question/17992/sending-an-sms-via-the-command-line/
you can find answers for many questions on https://together.jolla.com/
Oh and for triggering (receiving a SMS) you need to dive into dbus (search term only provided ;))
espec. dbus-monitor
Yet another pointer into a direction, but not actually a solution, incoming: Sailfish OS’s messaging stack is based around Telepathy, which works with Connection Managers, pluggable parts which create an abstraction around a messaging protocol, that communicate with Clients, which receive, display and send messages on behalf of the user without knowing the implementation details of the underlying protocol. Communications between these parts happen over D-Bus, although you can also use a library like telepathy-qt for that.
With that in mind, you could create a Telepathy client which receive messages from the telepathy-ring (the SMS connection manager) and send it to another connection manager, like telepathy-gabble (XMPP), telepathy-morse (Telegram) and so on. Or you could break the Telepathy convention and make your client include a protocol implementation to forward your SMS messages to.
This app seems to be able to send SMSs and manage incoming ones, so…:
Automagic
Seems great and very powerful, btw.
i have an app i made that monitors my phone and if i get an sms it mails me a copy, sends a ntfy notification and appends it to a Google sheet.
And if i put a reply in the google sheet it sends that via the dbus command and also appends to the comms db.
i should put it on github maybe.
I can just paste it here, it is more a script than an app. I took away a lot of stuff that was messy, so haven’t tested this exact version but it’s more or less what I have running to monitor my phones.
On the phones, you need to do:
pkcon install sqlite
usermod -a -G sailfish-radio defaultuser
And the google sheet has a sheet called SMS, and looks like:
Where if you write in an SMS in C, and put a phone number in A, it will send that and then add the timestamp to B.
import os
import logging
import time
from pathlib import Path
import configparser
import gspread
from google.oauth2.service_account import Credentials
from paramiko import SSHClient, AutoAddPolicy, SSHException
import smtplib
from email.mime.text import MIMEText
from email.mime.multipart import MIMEMultipart
from datetime import datetime
logging.basicConfig(level=logging.INFO, format='[%(asctime)s] %(message)s', datefmt='%m-%d %H:%M:%S')
logger = logging.getLogger(__name__)
# CONFIGURATION — edit these values or override via env vars
BASE_DIR             = Path("/path/to/base/dir")
SERVICE_ACCOUNT_FILE = BASE_DIR / "service_account.json"
LAST_SYNC_FILE       = BASE_DIR / "last_sync.txt"
SPREADSHEET_ID = "your-google-spreadsheet-id"
SHEET_NAME     = "SMS"
SCOPES         = ['https://www.googleapis.com/auth/spreadsheets']
# Email — can also be set via env vars SMTP_HOST / SMTP_PORT / SMTP_USERNAME / SMTP_PASSWORD / SMTP_FROM / SMTP_TO
SMTP_CFG = {
    'host':     os.getenv('SMTP_HOST',     'mail.example.com'),
    'port':     int(os.getenv('SMTP_PORT', '587')),
    'username': os.getenv('SMTP_USERNAME', 'user@example.com'),
    'password': os.getenv('SMTP_PASSWORD', 'password'),
    'from':     os.getenv('SMTP_FROM',     'user@example.com'),
    'to':       os.getenv('SMTP_TO',       'notify@example.com'),
# server.cfg — one section per SMS server, e.g.:
#   [SS1]
#   ssh.host     = 192.168.1.100
#   ssh.username = defaultuser
#   ssh.password = password
#   db.url       = /home/user/commhistory.db
cfg = configparser.ConfigParser()
cfg.read(BASE_DIR / "server.cfg")
# ========== State ==========
email_queue = []
# ========== Helpers ==========
def load_server_config():
    return {section: dict(cfg[section]) for section in cfg.sections()}
def get_sheet_client():
    creds = Credentials.from_service_account_file(SERVICE_ACCOUNT_FILE, scopes=SCOPES)
    return gspread.authorize(creds)
def get_sheet(gs_client):
    return gs_client.open_by_key(SPREADSHEET_ID).worksheet(SHEET_NAME)
def get_last_synced_epoch():
    if LAST_SYNC_FILE.exists():
        with open(LAST_SYNC_FILE) as f:
            return int(f.read().strip())
    return int(time.time()) - 86400
def update_last_synced_epoch(epoch):
    with open(LAST_SYNC_FILE, 'w') as f:
        f.write(str(epoch))
# ========== Email ==========
def queue_email(subject, body):
    email_queue.append({'subject': subject, 'body': body})
def send_queued_emails():
    if not email_queue:
        return
    logger.info(f"📧 Sending {len(email_queue)} email(s)...")
    sent = 0
    for email in email_queue:
        for attempt in range(2):
            try:
                msg = MIMEMultipart()
                msg['From']    = SMTP_CFG['from']
                msg['To']      = SMTP_CFG['to']
                msg['Subject'] = email['subject']
                msg.attach(MIMEText(email['body'], 'plain'))
                with smtplib.SMTP(SMTP_CFG['host'], SMTP_CFG['port'], timeout=30) as server:
                    server.starttls()
                    server.login(SMTP_CFG['username'], SMTP_CFG['password'])
                    server.send_message(msg)
                logger.info(f"✅ Email: {email['subject'][:50]}")
                sent += 1
                time.sleep(1)
                break
            except Exception as e:
                logger.error(f"❌ Email failed (attempt {attempt+1}/2): {e}")
                if attempt == 0:
                    time.sleep(3)
    logger.info(f"📧 Sent {sent}/{len(email_queue)}")
    email_queue.clear()
# ========== SSH ==========
def fetch_sms_via_ssh(host, port, username, password, db_path, last_epoch):
    sql = (
        f"sqlite3 {db_path} \"SELECT remoteUid || '\x1F' || "
        f"replace(replace(freeText, '\n', ' '), '|', '/') || '\x1F' || startTime "
        f"FROM Events WHERE type=2 AND direction=1 AND startTime >= {last_epoch} "
        f"ORDER BY startTime ASC LIMIT 1000\""
    for attempt in range(3):
        try:
            logger.info(f"🔌 SSH {host} (attempt {attempt+1}/3)")
            client = SSHClient()
            client.set_missing_host_key_policy(AutoAddPolicy())
            client.connect(hostname=host, port=port, username=username, password=password, timeout=15)
            stdin, stdout, stderr = client.exec_command(sql)
            out       = stdout.read().decode('utf-8', errors='replace')
            err       = stderr.read().decode('utf-8', errors='replace')
            exit_code = stdout.channel.recv_exit_status()
            client.close()
            if exit_code != 0:
                logger.error(f"❌ SSH failed (exit {exit_code}): {err}")
                if attempt < 2:
                    time.sleep(5 * (attempt + 1))
                    continue
                return ""
            count = len([l for l in out.strip().split('\n') if l.strip()]) if out else 0
            logger.info(f"{'✅' if count else '📭'} {host}: {count} message(s)")
            return out
        except (SSHException, TimeoutError, OSError) as e:
            logger.error(f"❌ SSH error on {host}: {e}")
            if attempt < 2:
    return ""
def send_sms_via_ssh(host, port, username, password, phone_number, message):
    escaped = message.replace('"', '\\"').replace('$', '\\$').replace('`', '\\`')
    cmd = (
        f'sudo dbus-send --system --print-reply --dest=org.ofono /ril_0 '
        f'org.ofono.MessageManager.SendMessage '
        f'string:"{phone_number}" string:"{escaped}"'
        try:
            logger.info(f"📡 SSH {host} → {phone_number} (attempt {attempt+1}/3)")
            client.connect(hostname=host, port=port, username=username, password=password, timeout=10)
            stdin, stdout, stderr = client.exec_command(cmd)
            out = stdout.read().decode()
            err = stderr.read().decode()
            client.close()
            if err:
                raise RuntimeError(f"dbus error: {err}")
            logger.info(f"✅ SMS sent to {phone_number}: {out.strip()[:80]}")
            return True
        except (SSHException, TimeoutError, OSError, RuntimeError) as e:
            logger.warning(f"Retry {attempt+1}/3: {e}")
    logger.error(f"❌ Failed to send SMS to {phone_number} after 3 attempts")
    return False
# ========== Core Processing ==========
def process_incoming_sms(line, server_name, sheet):
    if not line.strip():
        return False, 0
    parts = line.split("\x1F")
    if len(parts) < 3:
        logger.error(f"❌ Bad line: {line[:100]}")
        return False, 0
    uid_raw, text, timestamp = parts[0], parts[1], parts[2]
    try:
        ts_int = int(timestamp)
    except ValueError:
        logger.error(f"❌ Invalid timestamp: {timestamp}")
        return False, 0
    logger.info(f"📨 {uid_raw}: {text[:50]}")
        try:
            sheet.append_row([
                uid_raw,
                datetime.fromtimestamp(ts_int).isoformat(),
                text,
                'incoming',
                server_name,
            logger.info(f"✅ Sheet ← {uid_raw}")
            queue_email(
                subject=f"📨 SMS from {uid_raw}",
                body=(
                    f"From:    {uid_raw}\n"
                    f"Server:  {server_name}\n"
                    f"Time:    {datetime.fromtimestamp(ts_int)}\n\n"
                    f"{text}"
            return True, ts_int
            logger.error(f"❌ Sheet write error (attempt {attempt+1}/3): {e}")
            if attempt < 2:
                time.sleep(2)
    logger.error(f"❌❌ Failed to save {uid_raw}")
    return False, 0
def process_outgoing_sms(sheet, servers):
    Sends queued outgoing messages from the sheet.
    Row format: [phone_number, timestamp, message, direction, server_name, ...]
    Unsent rows have phone + message filled but timestamp empty.
    logger.info("📤 Checking outgoing SMS...")
    try:
        rows = sheet.get_all_values()
        logger.error(f"❌ Sheet read error: {e}")
        return
    if len(rows) < 2:
        return
    sent = 0
    for i, row in enumerate(rows[1:], start=2):
        if len(row) < 3:
            continue
        phone       = str(row[0]).strip()
        timestamp   = row[1].strip()
        message     = row[2].strip()
        server_name = row[4].strip() if len(row) > 4 else ""
        if not phone or not message or timestamp:
            continue
        if not server_name:
            logger.warning(f"⚠️ Row {i}: no server specified")
            continue
        server_cfg = servers.get(server_name)
        if not server_cfg:
            logger.warning(f"⚠️ Row {i}: unknown server '{server_name}'")
            continue
        success = send_sms_via_ssh(
            server_cfg['ssh.host'], 22,
            server_cfg['ssh.username'], server_cfg['ssh.password'],
            phone, message,
        if success:
            sent += 1
            now = datetime.now().isoformat()
            try:
                sheet.update_cell(i, 2, now)
                sheet.update_cell(i, 4, 'outgoing')
                logger.error(f"❌ Failed to update row {i}: {e}")
            queue_email(
                subject=f"📤 SMS sent to {phone}",
                body=(
                    f"To:      {phone}\n"
                    f"Time:    {now}\n\n"
                    f"{message}"
    logger.info(f"📤 Sent {sent} outgoing message(s).")
# ========== Main Loop ==========
def process():
    logger.info("🚀 Starting SMS Sync Service")
    try:
        servers        = load_server_config()
        gsheets_client = get_sheet_client()
        sheet          = get_sheet(gsheets_client)
        logger.info("✅ Connected to Google Sheets")
        logger.error(f"❌ Startup failed: {e}")
        return
    cycle = 0
    while True:
        cycle += 1
        logger.info(f"\n{'='*60}\n🔄 CYCLE #{cycle} — {datetime.now()}\n{'='*60}")
        last_synced = get_last_synced_epoch()
        logger.info(f"⏰ Fetching since: {datetime.fromtimestamp(last_synced)}")
        try:
            logger.error(f"❌ Outgoing error: {e}")
        total_processed   = 0
        highest_timestamp = last_synced
        for server_name, server_cfg in servers.items():
            required = ('ssh.username', 'ssh.password', 'ssh.host', 'db.url')
            if not all(k in server_cfg for k in required):
                continue
            try:
                sms_data = fetch_sms_via_ssh(
                    server_cfg['db.url'], last_synced,
                if not sms_data or not sms_data.strip():
                    continue
                lines = [l for l in sms_data.strip().split('\n') if l.strip()]
                logger.info(f"📦 {server_name}: {len(lines)} message(s)")
                for line in lines:
                    if len(parts) < 3:
                        continue
                    try:
                        ok, msg_ts = process_incoming_sms(line, server_name, sheet)
                        if ok:
                            total_processed += 1
                            highest_timestamp = max(highest_timestamp, msg_ts)
                        logger.error(f"❌ Line error: {e}")
                logger.error(f"❌ Server {server_name} error: {e}")
        logger.info(f"✅ Processed {total_processed} incoming message(s)")
        if email_queue:
        if highest_timestamp > last_synced:
            update_last_synced_epoch(highest_timestamp + 1)
            logger.info(f"⏰ last_synced → {datetime.fromtimestamp(highest_timestamp + 1)}")
        logger.info("💤 Sleeping 90s\n")
        time.sleep(90)
if __name__ == "__main__":
    process()
