mo
14 December 2025 16:52
1
I am writing a Sailfish application with QML/QT and C++, and want to use the ssl library.
#include <openssl/ssl.h>
But this does not work out. I tried using chatgpt but getting an error. Are there other methods to get this done?
sfdk engine exec bash
sb2 -t SailfishOS-latest-aarch64 bash
zypper in openssl openssl-devel
I’m getting Root privileges are required to run this command.
attah
14 December 2025 17:31
2
In the end you will want to declare it as a dependency (“Requires”) in your rpm spec.
The easiest is probably to just do it like that from the beginning.
My environment seems to have rotted - but i also seem to recall it has passwordless sudo somewhere.
vige
14 December 2025 18:14
3
That would be sfdk build-shell --maintain
sb2 -t SailfishOS-latest-aarch64 -R zypper in openssl openssl-devel
mo
30 December 2025 18:36
5
The maintain option now gives errors to me. I was able to again include openssl via
sb2 -t SailfishOS-5.0.0.62-aarch64 -R zypper --non-interactive in openssl openssl-deve
vige
31 December 2025 05:08
6
What’s the error message?
The correct way to install packages to build targets is via sfdk tools package-install command.
In your case it would be sfdk tools package-install SailfishOS-5.0.0.62-aarch64 openssl-devel.
I would suggest reading at least the output of sfdk tools --help.
mo
31 December 2025 06:30
7
Thank you, the error I got was [D] SOFT ASSERT: “!targetHasSnapshots” in file ../../../../sailfish-qtcreator/src/libs/sfdk/buildengine.cpp, line 792
I read the sfdk tools --help and listed the snapshots via sfdk tools list --snapshots
This gave
SailfishOS-5.0.0.62 sdk-provided,latest
├── SailfishOS-5.0.0.62-aarch64 sdk-provided,latest
│ └── SailfishOS-5.0.0.62-aarch64.default snapshot
├── SailfishOS-5.0.0.62-armv7hl sdk-provided,latest
│ └── SailfishOS-5.0.0.62-armv7hl.default snapshot
└── SailfishOS-5.0.0.62-i486 sdk-provided,latest
└── SailfishOS-5.0.0.62-i486.default snapshot
└── SailfishOS-5.0.0.62-i486.default.default snapshot
Via sfdk tools remove --snapshots-of SailfishOS-5.0.0.62-i486 I was able to delete all snapshots under SailfishOS-5.0.0.62-i486. Launching the command sfdk build-shell --maintain again created a new SailfishOS-5.0.0.62-i486.default snapshot, and didn’t gave any errors anymore, so problem solved. Tx for helping!
I got again the openssl-error when compiling after upgrading the sdk.
This solved the issue:
sb2 -t SailfishOS-5.1.0.11-aarch64 -R zypper --non-interactive in openssl openssl-devel
sfdk tools remove --snapshots-of SailfishOS-5.1.0.11-aarch64
