Hi,
before upgrading to 4.6, I want to make a full image backup of my current system running 4.5.0.25. But I only have a recovery image of 4.5.0.24. Is it safe to use the 4.5.0.24 recovery image for my 4.5.0.25 system?
Hi,
100% safe. It works OK even with 4.6.
Thanks! So it also boots when I reflash the normal 4.5.0.24 boot image after recovery?
I haven’t tested older hybris-boot.img because I didn’t need to (the latest one works fine). I had to use the older recovery with 4.6 because the 4.6 one didn’t work for me.
… to 4.5.0.25: Yes, definitely, because SailfishOS 4.5.0.24 and 4.5.0.25 are exactly the same, only the licence was altered.
P.S.: In general one can handle SailfishOS releases a.b.c.x
as “the same” with regard to the recovery image, when a.b.c
is the same. Corner cases are extremely unlikely but may theoretically exist.
Thank you both for your help!
