Hi.
I’m again having the issue where the battery of my Sony XA2 drains in around 24h whereas it used to last almost a week.
Last time, it was because apkd-bridge was eating up all the RAM, but it’s disabled right now, so it cannot be it.
I don’t see anything unusual or obvious in htop, except the lipstick -plugin evdevtouch -plugin evdevmouse -plugin evdevkeyboard process taking some RAM and CPU while the phone is idle (is this normal?).
So, my question is: how can I check if my battery is dying?
On linux laptops, I can check a file like /sys/class/power_supply/BAT0/energy_full_design and compare it to some other files, but I cannot find a similar file in SailfishOS.
Yeah that looks totally wrong, I guess sony guys never bothered, looks like counting manually how long it takes from close to 0% with given current is the only way (you’ll get sudden jumps and very short charging time or at least that’s how my n900s behave after years of usage with close to dead batteries)
