I have installed a few Android apps like Facebook, WhatsApp, Outlook. Actually I use only WhatsApp all the time.
The other apps are not active and I also turned off the background activity under Apps in settings. But sometimes I have a higher battery consumption. Then I look in the process list (usually via Crest) and I can see that all apps are running.
Even though I haven’t used them since the last time I stopped them hard?
My question now - how can I block android app that they are not make an autostart? The restart of Alvindalvik with the app “aliendalvik-control” not help. The apps start allone.
I’m not sure you can stop individual Android apps from running if they are ignoring the ‘do not run in background’ setting, but maybe those with more technical knowledge maybe able to help.
I use software like e.g. “APK Editor Studio” to modify the manifest file of the apk and I remove from it the permission to autostart, as well as all unneeded services (most of which are spyware sending usage statistics and bug reports to e.g. crashlytics) and so called “receivers” which get triggered by lots of various events (e.g. “Connectivity changed” or “Charging started”) and can autostart the app or its services. Then the software can nicely recompile and sign the APK and it is ready for installation. Only then I can be sure that no Android cr*p runs unattended, grabs my data and sends it God knows where, and eats my battery. I’ve been doing so ever since I started using BlackBerry Z10 and then Passport, both with Android app support like SFOS.
You’re welcome. It takes some practice, and sometimes it takes a few approaches to an apk, because in some cases removing some services or receivers can prevent the app from starting at all. But it’s worth the effort, because you end up with an app that’s stripped of all or nearly all undresired background activity, especially all those “crashlytics” or “campaign-tracking” services permanently uploading data wherever they want and eating battery. Same way you can also remove ads.
