With the latest critical security issues for the qualcom snapdragons releases 0, I wonder how the update process for hardware firmware is done in SFOS.
In Android, this is done by the OS updates (hopefully) released by the vendor. For example, Sony would release an update for my Xperia X phone which would also update the firmware of the Qualcom Snapdragon 650 to fix / mitigate the vulnerabilities.
How is this process implemented in SFOS? Are hardware firmware updates installed during the regular system upgrade process? Is there a manual way needed to do so? Or are they simply not installed at all, meaning such vulnerabilities are present for all eternity (or at least until you revert to Android, install the updates and then reflash SFOS)?
I’m really hoping for a direct statement from Jolla since this is a serious topic.
