I open this space for a problem that I can’t solve. I own a sony x II, with salfishOs 4.5.0.24 When I use hotspot the line is seen by the Pc, but it does not allow me to surf. My phone provider uses IPv4 and I have tried setting both dual and IP.
I have tried these solutions but to no avail.
Does anyone have the same problem as me? How did you solve it?
kind defactofactotum,
but did your xperia work right away? I tried to do a re-install, but it didn’t work. Could it be a smartphone problem? Could this happen? If yes, what can I ask the repairer? with android it works. But Sailfish is Sailfih.
no, I don’t think so. Seems more like a problem with the password authentication on your pc…mine worked straight away, I didn’t do anything special. If you’re really stuck you can try usb tethering to your pc…you have to install a small package first, search the forum for ‘usb tethering’
When I connect it to the PC , the PC reads the hotspot , prompts me for the password and recognizes it. But when I browse it duces me that I am not connected. I will try to follow the track you suggested. Then I will update the chat . thank you for the advice.
