REPRODUCIBILITY: All the time
OS VERSION: 4.6
HARDWARE: Xperia 10iii and XA2 using Android support
UI LANGUAGE: English
REGRESSION: Yes
The button/icon area within the Alarm card/area of the Overview screen that displays the state of the Paradox Alarm is not displayed.
This button used to be displayed in earlier versions of the OS.
If I press on the area where this button should be displayed an outline box is displayed.
None
<Launch Android version of Home Assistant Companion app
1)
2)
3)
Button should be displayed.
No button dispalyed
Custom text on lock screen
Mico G Installed on 10iii but not on XA2
Screen shots from the Home Assistant app showing what I mean
Shows the outline box
Shows what I see when I open Home Assistant
What I expect to see and used to see. This is taken off an Android phone in dark mode hence the dark background but shows the Disarmed button. This is where the Armed button is displayed when the alarm is armed.
Hi, I’m using in HA (Core 2024.8.3, Supervisor 2024.08.0, Operating System 13.1, Frontend 20240809.0) on Xperia 10 III, SFOS 4.6, Aqara camera alarm. As seen in the picture, everything works fine. Maybe there is a problem with the generated alarm card, probably the SFOS browser can’t render it correctly (like several other websites). Maybe you could try the new (ESR 92) browser "…packages are now available " if that suits for you.
Thank you for the reply. I am using the Home Assistant Companion app from Aurora Store. Does the app use the Sailfish browser to render the display?
I’ve just accessed my Home Assistant via both the Sailfish browser and my preferred browser Opera and the alarm status button is present in both browsers. It’s just the Android Companion app that is the problem on Sailfish. I know the Companion app works OK on an Android device.
I don’t use that application and I don’t even know it, so I don’t know how it is programmed, sorry. I only use an internet browser.
I’m happy to report that the recent update to 4.6.0.15 has fixed the issue. Plus another Android app that I used to use but had been unable to recently now also runs. Thank you
