Hint "Swipe down to access camera settings" always displayed
REPRODUCIBILITY: 100%
OS VERSION: 5.0.0.68
HARDWARE: XA2+
UI LANGUAGE: French
REGRESSION: I don’t know
Every time I open the Jolla camera, the hint to “Swipe down to access camera settings” is displayed.
I understand from the file /usr/lib/qt5/qml/com/jolla/camera/capture/CaptureModeHint.qml that this hint is supposed to be displayed only 3 times, based on a dconf key named /sailfish/camera/camera_mode_hint_count.
However, when checking with dconf dump /sailfish/camera/ (output in additional info) it seems this key camera_mode_hint_count never gets created, so the counter never increments and the hint is displayed on every single launch.
Unfortunately I am not familiar enough with QML to understand what prevents this dconf key to be created, but still wanted to report the bug.
None
  1. Open and close the default camera app more than 3 times since starting to use the phone
After the hint “Swipe down to access camera settings” have been displayed 2-3 times, it does not appear anymore.
The hint “Swipe down to access camera settings” appears every time, which ends up being rather annoying when using the camera regularly.
Based on these findings, it seems a workaround for this bug would be to create the dconf key with a value higher than 3 (ex: dconf write /sailfish/camera/camera_mode_hint_count 4).
However I am not sure how to remove a dconf key in case it would be useful for troubleshooting that I still don’t have this key created in my dconf.
So I used another workaround to disable the hint, which is to comment line 146 of /usr/lib/qt5/qml/com/jolla/camera/CameraPage.qml (which gives //CameraModeHint { z: 2 }).
In the output below, we see that the key camera_mode_hint_count was never created even after opening and closing the camera many times.
(Note: we see in this output the key of the other hint displayed by the camera, about swiping to access the gallery, which is named camera_roll_hint_count, this one works properly and is not displayed anymore after the first 3 times.)
[defaultuser@XperiaXA2Plus-DualSIM ~]$ dconf dump /sailfish/camera/
camera_roll_hint_count=4
[defaultuser@XperiaXA2Plus-DualSIM ~]$ dconf dump / | grep hint_count | sort
access_contact_card_hint_count=0
categories_attached_page_hint_count=3
change_month_hint_count=4
close_all_apps_hint_count=2
close_app_hint_count=2
download_upgrade_hint_count=2
incoming_call_hint_count=0
init_call_hint_count=0
menu_hint_count=3
pinned_launcher_hint_count=2
remorse_swipe_hint_count=2
return_to_home_hint_count=2
scientific_calculator_hint_count=1
settings_autosave_hint_count=4
split_view_back_hint_count=0
switch_keyboard_hint_count=2
Have the same issue on my Jolla 2026
On my Xperia 10 III all those hint_counts are at 0, yet I do not see hints anymore.
Also affected. JP26/5.2.17
Sorry for the simple suggestion, but have you disabled hints in settings>gestures? (unless of course there were other hints you’d still badly want to see)
Thank you for the suggestion, globally disabling hints would indeed work but this is not ideal for newcomers (especially since the tutorial cannot always be completed, Clock app cannot be opened in tutorial).
I couldn’t find a report for this so I created this one to have the bug tracked, but actually I already applied a workaround on my phone (commenting line 146 in the QML file mentioned above).
Still it would be better if this bug was solved for all SFOS users :slight_smile:
10iii / 5.0.0.77 also affected
Good catch. Still, those hints should only be shown the first time you open a given app.
JP 26, 5.2.0.18 affected
