Help with microg
I have followed the guide here in the forums but some packages are missing such as fakestore. My checklist in microg settings is like this
Can anyone help me out ?
you should start at the top, did you enable signature spoofing in Android App Support settings?
Edit: the relevant setting is called “deactivate Check of AAS system packages” or something like that (my translation might be wrong).
Try version 0.3.5 instead of the latest 0.3.6. It seems there is some issue with latest MicroG and SFOS App Support.
So issues on Xperia 10 III and Xperia XA2 but on C2 I was unable to make this work even with enabled option mentioned by @davidrasch
Seems to me like it is C2 problem only, but autor didn’t mention platform he was using
Shak’s screenshot looks like from a Sony and not from C2. However, the C2 (using SFOS 5.0) issue regarding Android 13 app support was discussed earlier here: Installing microG on Sailfish OS
The workaround mentioned again by Zielos is a good option for now for all SFOS variants.
I can confirm that version 0.3.5 works like a charm for xperia 10 iii. Notifications are also fixed from android apps
Thank You!
I had the same problem, but downgrading to 3.5, everything works fine on my Xperia XA2.
That’s good to hear. Now only revolut is left to work under microg
