My older bluetooth keyboards stopped working and i am trying to get e new one, particularly for using it with my xperia 10iii with sailfish os.
This is not successful. I now ran into the second bluetooth keyboard that is not working with the sailfish os. The keyboard can be paired and shows up in the device list but not as a keyboard. And so input is not possible. It works fine with other android devices.
The keyboards show only GAP as supported profiles when connected to my sailfish phone.
I have no idea how to proceed from here. Is there a limitation to what kind of bluetooth keyboards can be connected to sailfish os?
Any hints and advice welcome!
Doubt it helps but just my experience. I bought this one a while back as a cheap input device for a project I was working on at the time, can confirm it works fine on my 10 IV…
Mcbazel Foldable Bluetooth Keyboard,with Touchpad Portable Wireless Keyboard Compatible Bluetooth 5.1 for iOS, Android, MacOS,Windows System Laptop-Black: Keyboards: Amazon.com.au
ssh into your device and enter devel-su journalctl -f then try to connect the keyboard. Show us the output.
My first nonworking device: HZ-2758 (this one )
Device B6:7A:DF:XX:XX:X (public)
Alias: SmartRemote
Appearance: 0x03c1 (961)
Icon: input-keyboard
Paired: yes
Bonded: yes
Trusted: yes
Blocked: no
Connected: yes
LegacyPairing: no
UUID: Generic Access Profile (00001800-0000-1000-8000-00805f9b34fb)
UUID: Generic Attribute Profile (00001801-0000-1000-8000-00805f9b34fb)
UUID: Device Information (0000180a-0000-1000-8000-00805f9b34fb)
UUID: Battery Service (0000180f-0000-1000-8000-00805f9b34fb)
UUID: Human Interface Device (00001812-0000-1000-8000-00805f9b34fb)
UUID: Unknown (0000ae40-0000-1000-8000-00805f9b34fb)
Modalias: usb:v05ACp022Cd011B
Battery Percentage: 0x58 (88)
I can pair no problem, and after pairing it stays connected, but any button press shows no effect (it should be registering with mpris??).
journal has nothing interesteng. evdev_trace shows nothing.
Another keyboard that does not work, this one has two BT “channels”, so you can pair two devices and switch:
Device DE:9E:51:xx:xx:xx(random)
Alias: Ständer I
Paired: yes
Bonded: yes
Trusted: yes
Blocked: no
Connected: no
LegacyPairing: no
UUID: Unknown (0000ff00-0000-1000-8000-00805f9b34fb)
Modalias: usb:v04E8p7021d0001
Alias: Ständer II
Paired: yes
Bonded: yes
Trusted: yes
Blocked: no
Connected: no
LegacyPairing: no
